Safe Minimum Tire Tread Depth?
Guys,
What is the safe minimum limit for tire tread depth to prevent hydroplaning? At what tread depth should a motorcycle tire be replaced? I've seen it vary from our owner's manual, which states 2.5/32" (2mm) on the front and 3.8/32" (3mm) on the rear to as little as 1/32" (0.8mm). This difference in tread depth can translate into a lot of miles gained or lost. What is the best balance between road safety and tire life? Thanks, Jeff
BMW: 2024 R1250RS, 2016 R1200RS (For Sale), 2000 R1100S, 1975 R90S Ducati: 2008 S2R1000, 1998 900 SS/FE Norton: 1974 Commando 850 Triumph: 2020 Speed Triple, 1976 T140V Bonneville, 1973 TR7RV Tiger, 1971 T120R Bonneville, 1970 TR6C Trophy Last edited by jgrm1; 03-29-2005 at 03:20 AM.. |
There should be wear bars on the center of the tires tread. It will be a hump of rubber in one of the tread grooves, when its flush with the rest of the tread, its definitely time to replace. However err on the side of caution. Its always safer to have a new tire even if yours is only %50 used.
Bobby BMW Ducati & Husqvarna of Atlanta 06 HP2 SM, Akra Ti, RapidBike3, |
I'm thinking wear bars are 2/32" but could vary by tire type. For me, some tires will have other issues to warrent changing. After wrestling all these years, I bought a Harbor Freight changer (thanks for the push, Joe), makes it much easier.
I still have memories of a Norton rally 25 years ago of a guy sorting through the dismounts for something better than he had on. ("I'm on a low budget"). But at least he was there. Jim
down to jap bikes that run and a dead Norton |
Does anyone know the website for the Harbor Freight changer?
Changer Attachment
05 BMW R1100S BCR, 87 BMW K75C, 69 BMW R60US, 63 R69S sidecar project, 02 Suz SV650S, 01 Suz SV650S, 00 Suz SV650 naked, 01 Suz TLR fighter, 05 Suz DL650, 98 KTM 380 MXC Last edited by mullerjd; 04-01-2005 at 03:49 AM.. |
I thought bikes didn't hydroplane at all or at least verry little.Modern tires on motorcycles(esspecialy rears) actualy don't have that much thread to begin with.I think the rubber compound(100% silica best for rain) is the biggest influence on wet weather riding.So therefor I try not to ride with tyre's older then a year cause after a longer period the rubber tends to loose grip(altough normally you wear true a couple of tires during a year so this isn't a problem for me)The contact patch is so small that this is rarely a problem.For the front I normaly look att the wear bars but with the rear I probably ride a bit longer in case of emergency untill the point where there's almost no thread left(not in the winterseason though).
Look at this rear for instance(mez6) almost no thread in the center of the rear the front has to ride the road dry for the rear wich is the case with most modern tires.
Meet you at the bitter end... '09 Aprilia Scarabeo 250 i.e.
I think that we all go through this question but with differnet tolerances I am always suprised how much nicer the bike rides with new tires especially if the front has any cup in it
Steve ,93 LT Hacked 98 RT 02 S ohlins/laser 06 HP2 84 GS/KTM |
