jgrm1's Avatar
Wheel Bearing Life?
Riding back from Galveston today, while pondering my upcoming 36K miles service, I began to wonder about the life span of these wheel bearings. When should wheel bearings be replaced on the 'S?
-Jeff
BMW: 2024 R1250RS, 2016 R1200RS (For Sale), 2000 R1100S, 1975 R90S
Ducati: 2008 S2R1000, 1998 900 SS/FE
Norton: 1974 Commando 850
Triumph: 2020 Speed Triple, 1976 T140V Bonneville, 1973 TR7RV Tiger, 1971 T120R Bonneville, 1970 TR6C Trophy
Old 04-23-2005, 04:58 PM
tominator's Avatar
Send a message via AIM to tominator Send a message via Yahoo to tominator
No stoppes.....then 150K is not unheard of. They are a ***** to change however!
Tomas
If it has two fun bags I'm in!
2003 R1150RT, 2006 Cadillac CTS,2000 GMC Sonoma Slammed, 81 Harley Davidson Shovelhead Stroker, Supportive Wife,Jack Russel Terrier and a 18 year old who things he's 23.
Old 04-23-2005, 05:51 PM
jweicht's Avatar
Hadn't thought about this with the S before. The recommended front wheel bearing change interval on my R11RS was 50k. At least, I'm sure I read that somewhere and I changed them out then. Removing the old ones did take a little work but the new ones pressed right in after heating the wheel hub. May be different bearings on the S but I would think the procedure is the same.
'07 R1200GS Adventure "Brutus"
Old 04-24-2005, 06:00 AM
BMW Atlanta's Avatar
Send a message via AIM to BMW Atlanta Send a message via Yahoo to BMW Atlanta
no set interval I am aware of and we dont get a whole lot of high mileage "S"s coming through to poll. Check them regularly, it only takes 10 seconds if you have a centerstand and you should get a very pronounced effect when they do start to go when you hit on the brakes. With the proper puller removing the bearings is not all that bad and installation is very easy if you follow a couple simple tricks like freezing the bearings and heating up the hub. In some cases they drop in literally.
Bobby
BMW Ducati & Husqvarna of Atlanta
06 HP2 SM, Akra Ti, RapidBike3,
Old 04-24-2005, 07:43 AM
Hi,
My first set of bearings went at about 105,000 miles on the front, It was spotted when I went to get a new set of tyres, the vibration on the tyre balancer was quite noticeable.
I did change my front wheel sometime ago due to the discs cutting a new profile on the mounting stalks.
Front wheel and brake disc mountings.
So that was at ~75,000, without a bearing failure, but the replacement, something straightened from an early off road excursion at about 3000 miles failed at ~105,000, which is about ~33,000.
Who knows, I used to do lots of stoppies (@<50,000miles), but after my drive train failures I’m a little reluctant now-a-days.
Adrian.
Old 04-26-2005, 06:56 AM
roger albert's Avatar
I get lucky and see them work that way pretty often too.
It's worth waiting a few minutes between the left and right sides,
so that whichever bearing is installed 1st gets a chance to absorb
some heat and expand. Without that, I've had the 1st bearing fly
out while pounding in the 2nd (not a problem of course, if you're lucky
enough for the 2nd set to drop right in too.)
99 R11S w/ BBP, InDuct, Öhlins, PVMs, Braking, SJ-Filter, ZTech, HIDs
D675 R90Cafe R60/2 M900 SV650-SS CBR150R XR125 & CRF175 Motards
OnRoad OffRoad Cycles, Austin, TX: BMW, Ital, Suspension, Electrics
Dealer for K-Tech, JRI, GP Suspension, Penske, Öhlins, RaceTech, Elka, Wilbers, IKON & Works
www.ororcycle.com
CMRA EXPERT #841
Various Formula 5, 6 & 7 championships 2006-2012
A3, Navigator,
Old 04-26-2005, 12:18 PM
