Kam Kam is offline
Question Changed front tire
Well, thanks to a good buddy (ie very patient) I changed 4 tires this weekend...3 by myself! Coats tire machine...very easy to use.
A question: after remounting the front wheel on the S, the first time I pulled the brake lever it was really soft, but built up resistence w/ two or three good pulls. Is that normal? I was very careful w/the calipers, and zip tied them to the mounting brackets whilst the wheel was off.
Oh yeah, and static balancing really shows you how OCD you are....
Kam
'01 R1100S going bye bye for an 06 1200GS, '02 aprilia RSV mille R, '03 tuono R, Kelly's bar&lounge
how about never, does never work for you???
Old 07-04-2005, 01:27 PM
SCOTTinNJ's Avatar
yes, absolutely normal. watch the pit crew careful at the next daytona 200. they pump the front brake like mad after the tire is installed and before the rider pulls out away from them. you're simply reseating the calipers and building pressure in the system.
Old 07-04-2005, 02:48 PM
Kam Kam is offline
Great, thanks Scott.
Kam
Old 07-04-2005, 07:55 PM
roger albert's Avatar
Yes, totally normal.
You can really scare yourself if you don't pre/reseat the pistons/pads.
99 R11S w/ BBP, InDuct, Öhlins, PVMs, Braking, SJ-Filter, ZTech, HIDs
D675 R90Cafe R60/2 M900 SV650-SS CBR150R XR125 & CRF175 Motards
OnRoad OffRoad Cycles, Austin, TX: BMW, Ital, Suspension, Electrics
Dealer for K-Tech, JRI, GP Suspension, Penske, Öhlins, RaceTech, Elka, Wilbers, IKON & Works
www.ororcycle.com
CMRA EXPERT #841
Various Formula 5, 6 & 7 championships 2006-2012
A3, Navigator,
Old 07-04-2005, 08:45 PM
