New technical info for adjusting throttle position sensor
On the IBMW site there is a new and interesting technical piece regarding the adjustment of throttle position sensors.
The full title of said piece is: 'Zero=Zero method for adjusting BMW oilhead throttle position sensor to reduce or eliminate engine surging' Whilst it is not specifically aimed at the 'S' it does make interesting reading. However, I also think it would require a degree of bravery to tackle this procedure. Worth taking a look at on http://www.ibmw.org/ Also look at the disclaimer now issued regarding incompatible procedure. |
| All times are GMT -8. The time now is 09:18 AM. |
