charcoal cannister removal
What lines need to be vented or pluged if you take the cannister off The BMW R1100S
Old 01-27-2001, 02:44 PM
Hello
Just do a search for charcoal canister on this post and you will find all the info you need. The big list, IBMWR, has a detailed procedure for the removal of the canister on an RS. it is full of good info.
Good luck
Old 01-27-2001, 04:08 PM
The details are in the archive, but the simple answer is that you need to plug both the nipples at the bottom of your throttle bodies (where hoses are now), and reroute the hose that goes from your gas tank vent back to the canister. This 2nd hose can just be re-routed next to a similar hose that is the gas tank overflow to exit near the right footpeg.
Once you do this, the canister, solenoid, and unused hoses can be discarded.
- Mark
Old 01-27-2001, 08:11 PM
