718Rider's Avatar
Send a message via AIM to 718Rider Send a message via Yahoo to 718Rider Send a message via Skype™ to 718Rider
Need a Torque Wrench
I want to buy a torque wrench to work on my R1100GS. Any suggestions? I don't want to spend a ton of cash. Thx,
Tom
Current Rides
2007 R1200S
Silver, Vanderlinde Full Exhaust
Old 10-07-2005, 09:36 AM
Biggest Member
gigantic's Avatar
Send a message via AIM to gigantic Send a message via Yahoo to gigantic
spend a ton of cash and buy a good tourque wrench. i had a cheap beam wrench >$30 at sears that i used to tourque my valve adjuster lock nuts. that bargain tourque wrench cost me $1525 for a full engine repair after one of the nuts backed off and got sucked down the cam chain galley.
if you're on a budget, do like i did, and go to a pawnshop. you should be able to find a good quality wrench for around $100. believe me it's worth it.
Lance
Old 10-07-2005, 10:24 AM
718Rider's Avatar
I was thinking betwee $50-$100 - should I get a 3/8 or 1/2? I'm a noob when it comes to tools.
Current Rides
2007 R1200S
Old 10-07-2005, 10:30 AM
Flatbutt1's Avatar
IMO the 3/8 is all you'll need
big blue tricycle
stare down the darkness and watch it fade
Old 10-07-2005, 10:36 AM
SCOTTinNJ's Avatar
i disagree with gigantic. i bought two beam-style torque wrenches from sears. one's a 3/8" and the other is 1/2". they work great.
my understanding is that they are more accurate than the click-style, as those need to be recalibrated every so often.
Talk Less, Say More
ckcarr's Avatar
Location: Moab Utah. Home of wierd red & orange radioactive stuff... And 1 billion tourists.
Sears is just fine for the garage mechanic.
On sale and then with the Craftsman Club they are a great bargain.
Roger wrote some interesting stuff long ago about torque wrenches and where the accuracy is not necessarily in the perceived wrench/cost factor but quality and condition of the fastners. There's all kinds of stuff if you do a search.
You sure wouldn't need a 1/2 inch. And probably could get along with a 3/8 inch-lb wrench on this bike as the Craftsman also has the NM on it.
cRaIg CaRr
2000 Dyna FXDX, 2001 Sportster Sport, 2000 R1100S,2007 R1200S,2015 rNineT,2015 Gold Wing, 2023 F850GS,2023 R1250RS, 2017 Triumph T100, 2019 Jeep Rubicon, 2005 Jeep Sport, 2001 Corvette, 1978 Porsche 928. 2001 GMC Sierra 2500HD, 22 pairs of shoes. 24 bottles of beer.
Old 10-07-2005, 10:41 AM
Well, you might end up needing two ... one for low end stuff (in lb and up to 10 ft lb or so) and one for the higher end stuff (something that can go to 110Nm [at least] to get things like the wheel bolts tight). I've seen that many torque wrenches aren't very accurate at the extreme ends of their range.
Go to Sears and pick up a couple ... $89.99 I think is the highest. BTW, I think the only way that the Craftsman Club is valid anymore is online .. they aren't running those in-store specials any longer or that's what my buddy who works there sez ...
aka Rev Z-Man -- RIP www.bmwforums.net
- 1950s Ford 9N Tractor
- 2021 Subaru Outback Onyx XT
- Drummer for 12 Days Straight
Old 10-07-2005, 11:47 AM
Thanks for the plug, Gigantic. Let me go through my stash at the house, I never sell any Snap-On stuff here at the shop.
Jim
down to jap bikes that run and a dead Norton
Old 10-07-2005, 01:30 PM
tm1100s's Avatar
I'm with gigantic. My recommendation is to buy the best you can afford. I have Snap-On and Sears and the Snap-On are definitly the finer tools.
Also, consider that they need to be checked a calibrated every once in a while ( I check mine every two years or so). If the thing is dropped, I wouldn't trust it again until it's checked. Quality and calibration make a difference when you're working in ranges between 10 - 35 lb/ft where small errors can mean big trouble.
tm
(R12, R11, R1) + 00 then S, S, /7
Same here. snap-on all the way. I just spent $150 to get my prop of my boat because I used the china tools that I keep on my boat instead of taking my good stuff with me. It rounded out the allen bolt. They had to cut part of the cone to get vice grips on it.
Lane
2005 Boxercup, 2013 R1200GS Rallye, 2011 Triumph 675 Daytona, Honda MB5, 2011 KTM300xc, 1975 Bultaco, 1992 Beta, 1972 Aermacchi
Old 10-07-2005, 01:54 PM
718Rider's Avatar
Should I get NM of lb/ft?
Current Rides
2007 R1200S
Old 10-07-2005, 02:18 PM
Barback King
Rapid Dog's Avatar
...my Craftsman has both...
R11S CNC BARBACKS
Old 10-07-2005, 03:19 PM
Torque Wrench
Craftsman has a 3/8" click-style which has both ft-lb and N-M windows. Put some tape over the ft-lb and use N-M as that is what the manual refers to. You don't want to get confused, or you'll be learning about heli-coils.
Also, when not using the wrench it is good practice to set it down near 0.
Stuart
Old 10-07-2005, 04:23 PM
If you're planning on doing all your work according to torque specs, you will need 2 torque wrenches, one for high end, one for low end torque. The click style keep their calibration better if dialed back to 0 after use and if they're stored in moderate temps (read store inside, not in the cold as hell/hot as hell garage/tool shed)
I've had my Craftsman torque wrenches for 15 years, use them 6-8 times/year and they've always been well within spec every time I've calibrated them.
Old 10-07-2005, 11:19 PM
I just added a clicker style inch lb torque wrench to the 3/8" & 1/2" to cover all the bases. Very handy for preloading bearings & small fasteners.
John B.
03 R1100S Prep(wife's), 02 Futura, 92 907ie, 89 Transalp, 87 R80/100, 82 Morini 3.5 sport, 76 R90/S, 73 R75/5
90 535im & 95 525i Touring
65, 66 Alfa Romeos
Old 10-08-2005, 12:00 PM
ExarKunONe's Avatar
Send a message via AIM to ExarKunONe Send a message via Skype™ to ExarKunONe
Beam type from craftsman, its like $25. Works great, just remember that the handle is swivled for a reason. you shouldnt touch the plastic to the metal when taking a reading and the wrench has to be in motion for correct readings. The nice thing about those is you never have to calibrate it, just bend the needle back to zero
Old 10-10-2005, 01:09 AM
