I am seduced, a wonderful motorcycle. Ironically it seems to have many the boxer twin/drivetrain quirks that my old r65ls had, so I was comforted that I hadnt jumped into something i was not ready for. Stupid questions:
1. Are smokey start ups typical during break in? After doing a sub 4500 rpm 60 mile ride the bike sat overnight. Upon start up he next day, which was cold and very humid,the bike appeared to be burning of a lot of excess oil, very smokey exhaust until warmed up. 2. Is there no control for the fuel tank, or is it automatic? I didnt want to look so stupid and ask the dealer. I couldnot find the typical petcock that i was used to. -josh |
I dont have smoky start ups. Sometimes when its really cold, there is some white smoke. Cold startups are the only tough starts. Unfortunately, the boxers still have a manual cold start lever, unlike the K engines.
The fuel tank is automatic, no fuel levers. |
Newer bikes will smoke a bit on startup if you leave them on the sidestand overnight. It shouldn't happen if they motor is kept level, or once the rings are fully seated. No harm done.
thanks, I appreciate the info.
You should see a startup from the sidestand with my old K100, thatīs a smokeshow!!
Are you sure it is smoke and not steam? If it is visible throughout the warmup period and it is smoke, then you've probably got a serious problem. White "smoke" that immediately evaporates is steam and normal, especially on cold humid mornings.
The S puts out more steam during warmup than most bikes. I think it has to do with the catalytic convertor doing its job during the warmup period, burning the rich mixture to CO2 and water vapor. I noticed more steam from cars during warmup when catalytic convertors first appeared. (Yes, this dates me as driving back in the 70's.) - Mark |
well mark, no i am worried, but i guess yes it could be defined as steam, I will test it and get back to you, the bike literally only has 60 miles on it, I doubt the rings are completely seated and it was an incredibly moist and cold morning. the symptoms clearly ended after a minute or so of riding.
Appreciate the heads up. |
