Guest
Posts: n/a
My front shock is shagged and I was wondering if they are rebuildable?
Has anyone, whom has removed their front shock, noticed if it has an easily removable top? Cheers, Frank |
No Info on (t)his member
Probably by some very expensive outfit that may or may not be convienent to your location.
Save your Dinars/Kopeks to purchase Ohlins/Works/Penske.They will transform the bike into a very compliant partner in road gobbling. They WILL be rebuildable –*but probably very expensive and inconvienent. ![]() I personally found the stock units unfit for anything but freeway droning...barely. jeff clark |
Yes they are rebuildable
If you type shock rebuild in the search engine you should be able to find several post on the subject. And if I recall it's a lot cheaper than aftermarket shocks. A few people have talked very highly of L.E. The shop is Lindemann’s Engineering, (408) 371-6151 (the west coast) |
I have had mine rebuilt and I think Lennie also did. He is just a touch closer to you than I am so he may have some info on where to get them done. Cost: Olins rear $900, rebuild stock $150
Rad |
Guest
Posts: n/a
Thanks for your input guys, I have sent Lennie an email asking him for his advice and yes he is a lot closer to Tasmania.
I also did a search using shock rebuild rather than rebuildable shock and found some threads. Cheers Frank |
