Talking "Wheelie" on a R1100S
Fellow "S" Riders,any tips on pulling a wheelie? Nomatter how hard I yang the throttle, the front wheel only lift a inch or so.....
Old 06-22-2001, 11:42 AM
jdlowery's Avatar
Post
Torpedo,
I asked the same question a few weeks ago and received some good info (do an archive search) and some useless chatter. In any case, it seems that the S has a tough time with wheelies in stock form. From some of the post it seems that once the chip and pipe are changed it's a lot easier to lift the fron wheel.
Jim
'01, R1100S
'80, R65
Old 06-22-2001, 12:17 PM
JPF JPF is offline
Post
let your bike brake in and then it's easy...
Old 06-22-2001, 12:46 PM
Wink
easiest to begin with is the power wheelie;
1st gear 5500rpm sit upright and as far back as possible on the front part of the seat, then release the throttle till the nose dives in , then wack the throttle open while tugging on the bars.
ps. Keep the rear brake covered so you can allways prevent the bike from flipping over.
The S is not an easy bike for it, because of the weight on the nose. A trailie type or a Blackbird type is much easier, the first because of the seating position, the second because of the smooth power buildup, chaindrive and the sweet balancing point.
I would advise to hone your skills on a cheap dirtbike before flipping your expensive
S over backwards or sideways.
Old 06-22-2001, 01:51 PM
D.Carmichael's Avatar
Exclamation
If this is something you have to do, make sure there less than a 1/2 tank of fuel.
(the less the better)
And if you've never wheelied a bike before the S isn't a good place to start, I would not advise it.... but it's very capable.
Old 06-22-2001, 02:52 PM
Post
Well, I pulled my very first wheelie on this bike, it came up about a foot or two (I think, but more than an inch or two). I basically had it at 5,000 rpms in 1st gear and just whacked it while lifting the bars a bit.
Now after practicing here and there (AND letting the bike break-in!) I'm able to do them more controlled by just whacking the throttle above 4K and just jerking up the bars a bit.
It's a heavy bike, but like others I have heard that the exhaust and chip combos out there really make it "wheelie happy" -- if that's what you like.
Old 06-22-2001, 06:03 PM
Wink
I wouldn't classify that as wheelie...but OK
Old 06-22-2001, 06:09 PM
JPF JPF is offline
Post
funny... i get the wheel up in corners now that i have her tuned, a good pipe and ram air. front comes up a few inches in 2nd too.
Old 06-22-2001, 10:16 PM
Post
I was able to get her up tonight a little bit (6 inches or so) while running at 40 and dropping down to 2nd and whacking the throttle.
Can't wait to tune her a bit more....
Old 06-22-2001, 11:08 PM
Thumbs up
Courtesy of BMW2K
Old 06-22-2001, 11:21 PM
Post
Now *THAT* is a wheelie!
[This message has been edited by ErricZ (edited 06-23-2001).]
Old 06-23-2001, 06:49 AM
Andrew Stemp
Guest
Posts: n/a
Post
Get some luggage bags and fill them up. Wheelies are no problem.
Andy
Old 06-23-2001, 12:05 PM
peterboxer's Avatar
Send a message via ICQ to peterboxer
Talking
wheelies with the S ?
no problemo ....<IMG SRC="http://www.pelicanparts.com/ultimate/image_uploads/01r1100rt_wheeling.jpg">
. with an RT .... :-)
Old 06-23-2001, 01:04 PM
Post
and just "whack it".. what does that mean exactly?
Old 06-23-2001, 01:53 PM
No Info on (t)his member
jclark's Avatar
Post
...i would expect it to mean "Very Good Balance"
Old 06-23-2001, 01:59 PM
Joe Joe is offline
Joe's Avatar
Send a message via ICQ to Joe
Post
PETERBOXER'S PICTURE
Old 06-23-2001, 02:00 PM
Post
Andrew,
A much cheaper alternative to the luggage racks is to put your wife/girlfriend on the back and tell them to hang on ... tight!
Regards
Paul
Old 06-24-2001, 12:06 PM
