-   BMW R1100S / R1200S Tech Forum (http://forums.pelicanparts.com/bmw-r1100s-r1200s-tech-forum/)
-   -   InDuct & power flow filteron, otherwise stock 2001 R11S, will it run too lean? (http://forums.pelicanparts.com/bmw-r1100s-r1200s-tech-forum/25057-induct-power-flow-filteron-otherwise-stock-2001-r11s-will-run-too-lean.html)
Jasper229 08-02-2001 06:58 AM
I have a 2001 R1100S. It is completely stock but, I have a Power flow filter coming and may get one of those InDucts. My concern is that the bike will run to lean. It still has the Cat and O2 sensor.
Any suggestions?
Later going to get the Vanderlinde exhaust.
Joe 08-02-2001 08:00 AM
Jasper229
Here's a thread that might help you.
http://www.pelicanparts.com/ultimate/Forum19/HTML/001666.html
JOE http://www.pelicanparts.com/ultimate...oads/MINIS.jpg
Jasper229 08-02-2001 09:36 AM
I see that this particular person on the thread is using a K12RS fuel regulator, so he should be getting more fuel than I would.
Am I correct?
Joe 08-02-2001 10:02 AM
Yes that is correct, cost $60 plus your time.
Rapt 08-02-2001 10:04 AM
Yes, more fuel. There are a couple threads on that too. Although until you do the pipe the amount lean is going to be relatively small.
In some sense FI makes the fuel thing MORE work than a carb since its not a closed loop system, or even on that measures mass air flow.
lennie 08-04-2001 02:58 PM
Jasper,
I ran the original InDuct about 2 1/2 years ago with an aftermarket Foran exhaust, cylinder head porting, disconnected O2 sensor, and later a K&N filter with the stock chip for about 18 months. This is not to say it was not too lean, but it did not seem to have any detrimental affect on the engine whilst providing good power. The motronic will compensate to a certain degree, but the real gains for any change will benefit from a chip change.
I still run the stock chip with an increase in fuel pressure that seems to improve the combination. The next thing is to custom tune the bike for its current setup.
Regards, http://www.pelicanparts.com/ultimate/smile.gif
Lennie
[This message has been edited by lennie (edited 08-04-2001).]
zx9rmal 08-04-2001 06:51 PM
what's the difference in psi between the S and K12RS fuel regulators?
Thanks.
Mal
lennie 08-05-2001 03:16 AM
The S runs at 3 bar and as far as I understand the K runs at 3.4 bar.
Regards,
Lennie
wh1dog 08-05-2001 11:06 AM
Can someone post more info on the K12RS fuel regulator. Cost? Install procedure. other useful info. Thanks.
rob_wijhenke 08-05-2001 12:20 PM
http://wijhenke.net ->R110S->Fuel Pressure
Andrew Stemp 08-05-2001 01:26 PM
I have a laser mid section with TBR Carbon Cans, I also have a K&N filter fitted and a K1200 3.5 bar pressure reg with the O2 sensor still connected and original Motronic chip. I have advanced the ignition timing also and run on 97 octane fuel.
The biggest difference I have noticed with the changes is that it is much more willing to pull at higher engine speed, that's 5000rpm's to the rev limiter and it will fly up to an indicated 150mph. (Track only of course;-)) This may not be useful in everyday riding but it does help to keep up with your buddies on their jap missiles.
Andy
jclark 08-05-2001 02:34 PM
How dos one 'advance the timing'?
I was under the impression that that was one of the functions of the chip.There is a seperate adjustment?
Oh, goody!
Dish.
Por favor, of course...
jeff
needs something else to doink with...
Rapt 08-05-2001 03:12 PM
The timing advance instructions are on the IBMWR site under the tune-up and tuen Super tuning techniques...
I'm dying to try it to mine but its still under wanrantee and I'm pretty certain that fiddling the ignition timing would not be a good thing if the engine went south.
Andrew Stemp 08-06-2001 11:58 AM
It's dead easy. Take off the front plastic cover, undo the three hex screws on the timing plate, twist and retighten, takes about half an hour.
Andy
roger albert 08-06-2001 12:32 PM
Hi,
Yes, it is dead easy. I'd say Rapt is right that a misadjusted timing setup _could_ void warranty. Most likely only if you holed/burnt a piston or valve though. The combo of too much advance and leanness would be plenty cause for warranty denial, so I'd be careful about that combo.
To answer Mr. Clark's question, yes, timing variation/advance/retard _is_ done under engine control. The base mechanical static timing can be adjusted though. The engine computer will vary the timing from whatever mechanically set baseline you've dialed in.
later
roger
