I have 2004 R1100S with ABS. There is a significant difference in braking power when the engine is on and off. When I pull out the bike from my garage, the brake is almost scary weak. Once the engine is on, it works fine. Is this normal? or do I have an issue with brake?
Edministrator
Completely normal. Your bike has servo-assisted brakes that require the engine be running.
Good post? Leave a tip! O - $1 O - $2 O - $3 |
Yup. Normal. It's a feature, not a bug.
99 R11S w/ BBP, InDuct, Öhlins, PVMs, Braking, SJ-Filter, ZTech, HIDs D675 R90Cafe R60/2 M900 SV650-SS CBR150R XR125 & CRF175 Motards OnRoad OffRoad Cycles, Austin, TX: BMW, Ital, Suspension, Electrics Dealer for K-Tech, JRI, GP Suspension, Penske, Öhlins, RaceTech, Elka, Wilbers, IKON & Works www.ororcycle.com CMRA EXPERT #841 Various Formula 5, 6 & 7 championships 2006-2012 A3, Navigator, |
You should have a silver sticker on top of your gas tank with the lawyer induced warning about the servo assist.
Wildduc '67 Ducati 250 Monza '04 BMW R1100S '88 Alfa Spider Quad |
Of course if your battery dies and the engine is not running the brakes go away. If you are concerned about brakes when you move it from the garage just turn the ignition on and see if the brakes work more easily. I would try it now but I'm at work.
cheers... jack '04 R1100SA |
