Oil filler cap....arrgh!
I picked up my 04 R1100S a couple of months back, so far it's been a fun bike. Haven't had much chance to ride it (or my Aprilia) as it's been raining here in NorCal. I haven't really done any "work" on the bike myself outside of finding out the battery is in the worst possible location of an bike I have ever owned
OK, so I want to check the oil level and maybe add a little if needed....I have never really given much thought to it...open the oil filler cap and put the oil in...well, when I got the bike it had one of these filler caps installed. ![]() Quote:
Anyone have an idea as to how to get this thing open that DOESN'T involve me taking the valve cover off ?? I have had the 6K tuneup done in late Sept...(A&S BMW) the oil was changed....perhaps the cap was over thightened?? Sorry for the ramble..... |
Barback King
...That sucks...not every aftermarket product is a good idea.
I always wondered about those things, bummer if you don't have the key on the road... If you have to take the valve cover off, it's no biggie. The four valve cover screws and it's off, clean the gasket and re-assemble. Otherwise, the male portion (cap) should back out either way... g'luck
R11S CNC BARBACKS |
had that problem with one of those once. it really is not a big deal to pull the cylinder cover. four bolts and the coil wires to the spark plug...and a little oil on the floor. i have not found a completely acceptable replacement, not that the oem is worthwhile either.
repoe3
I couldn't repair your brakes, so I made your horn louder. 2009 GSXR 750 2004 Tuono 2004 R1100SBX |
![]() The mention that the oem isn't worthwhile... Any particular reason? |
dont get me wrong, i have not a long list of gripes over the bike. this isjust one of those little things, you know, like dry-rusted splines at 15k miles. simple stuff :| repoe3
oh, but to let you know how to make one of those oil cap thingies work better, the aftermarket one...drill a slight detent for the grub screw to grab the cylinder cover. that would do it. from a functiona standpoint, that replacement cap is the better one. the ones that are machined aluminum that fit in the oem plastic fitting in the cover are not very good at all. tried em both, i have.
repoe3
At six years and 39K miles, my OEM is going strong. No leaks or nothin'. It even coordinates with my black paint.
-Jeff
BMW: 2024 R1250RS, 2016 R1200RS (For Sale), 2000 R1100S, 1975 R90S Ducati: 2008 S2R1000, 1998 900 SS/FE Norton: 1974 Commando 850 Triumph: 2020 Speed Triple, 1976 T140V Bonneville, 1973 TR7RV Tiger, 1971 T120R Bonneville, 1970 TR6C Trophy |
Living on borrowed time!
'attempt. not sure why we cant have a snap in place, gasketed, and threaded component that actually seals off the hole rather than fill most of the void and let hot oil weep out.'
remove the OEM filler plug. remove the insert. Cleand the valve cover and the insert. Use yamabond #4 on the inseert. Reassemble. No leaks after 25K miles. I drilled a little hole in the OEM plug and a corrosponding hole in a valve cover fin. Some safety wire thru this and it's not coming off accidentally (it's a track day mod anyway so WTF)
Better a has-been than a wanna-be 'I am John Andrew Moffett of the Clan Moffat and by god I live, love, seek, fail, grieve and die as I so choose and I call no man master save me'. |
so I popped the valve cover off....and got the cap off only after gripping the inside with some visegrips
![]() it looks like the 2 screws that "hold" the insert were creating there own little 'groove' on the inside of the valve cover (I took some pics but I don't have time to download/post them right now) I can't quite figure out how to get the insert out though now as I can't quite figure out how the screws were/are tightened down....allen wrench?? hmmm....I think I will be going back to the stock if I can get this thing out... |
Those inserts are notorious for slipping. I'd take it out. Theres a rubber donut washer holding it onto the valve cover. You've got to just muscle it with some pliers or vice grips pushing it out from underneath. (within the valve cover). The oem one should work fine with some washer replacements along the way. Those cool/heat cycles due tend to where down the washer.
I had one on my BCR and the thing popped out while I was on the highway.
Got a nice oil bath on my leg. I'm back to the OE plastic and safety wire
05 BMW R1100S BCR, 87 BMW K75C, 69 BMW R60US, 63 R69S sidecar project, 02 Suz SV650S, 01 Suz SV650S, 00 Suz SV650 naked, 01 Suz TLR fighter, 05 Suz DL650, 98 KTM 380 MXC |
I have one If you finger tighten it it will not leak (over 50,000 mile on an old GS) and I never use the key
if you use the key and tighten it will leak
Steve ,93 LT Hacked 98 RT 02 S ohlins/laser 06 HP2 84 GS/KTM |
I'm with Mr. Abella.
I only had a problem once. Overtightened by dealer during warranty service. Takes very little to overtighten them. I do finger tight and then a very small tweak with an allen. When new, the caps come with a keyring with a stubby little 6mm allen.
99 R11S w/ BBP, InDuct, Öhlins, PVMs, Braking, SJ-Filter, ZTech, HIDs D675 R90Cafe R60/2 M900 SV650-SS CBR150R XR125 & CRF175 Motards OnRoad OffRoad Cycles, Austin, TX: BMW, Ital, Suspension, Electrics Dealer for K-Tech, JRI, GP Suspension, Penske, Öhlins, RaceTech, Elka, Wilbers, IKON & Works www.ororcycle.com CMRA EXPERT #841 Various Formula 5, 6 & 7 championships 2006-2012 A3, Navigator, |
thanks for all the ideas/info guys
I went with the stock filler cover after I got the other one out. I do find it odd that the female portion of the oil filler cover just presses into the cover? But then again it's a BMW I guess this is better than stripping out the magnesium ![]() I am going to try and include a few pics of the chewed up portion- FYI
I'd like to try the plug/fitting you took out, if you care to get rid of it...thanks,
Paul |
my oem must have heard me bath-mouthing it yesterday. i got home, started up the bike to go fill it up as it looks mild enough to ride to work the rest of the week. as i am taking off, i hear this burble sound. i look down and the filler cap is vibrating to the engine pulses. some serious air leakage coming out aroudn the thing and the slightly more than average weepage. sheesh.
repoe3
Or at the very least bring it to the range and we will shoot it.
Except for a few cases the murderCycle rate is relatively low on this board, keep up the good numbers. |
well, I could try and hit it....I may need the "red light"
