Anyone tell me the difference between
these two V belts for a '99?
04 12 31 1 341 779 ribbed v-belt 04 12 31 7 681 841 ribbed v-belt (4PK592)
big blue tricycle stare down the darkness and watch it fade |
The 04 12 31 7 681 841 ribbed v-belt (4PK592) is for racing and HP models.
Good for .3hp gain but the spin up is knocked down by 5ms.
Living on borrowed time!
FB;
I intend to visit the local import auto parts store this weekend with both an OEM belt and the 'tribal knowledge' goodyear gatorback belt that's in reality 1/4" too long for an S. (the goodyear belt takes up all the adjustment room for the alternator brand new) in an attempt to find the perfect belt. progress or lack thereof to follow...
Better a has-been than a wanna-be 'I am John Andrew Moffett of the Clan Moffat and by god I live, love, seek, fail, grieve and die as I so choose and I call no man master save me'. |
It would be nice if someone would clear up issues concerning the best choice of belts. It has been debated for some time and most of us are in need of a new one. Let us know what you find out.
'99 R1100SA, ;06 DR650, '84 R100RT |
unsafe at any speed
I have heard panty hose can be used for a road side fix... somebody should investigate that option too.
Bill Swartzwelder 2002 R1100S Prep/ 2024 Tenere 700 Last edited by wswartzwel; 12-30-2005 at 08:04 PM.. |
Gus Wilson from Model Garage used that trick in the 60's, was in the pre-pantyhose days.
Jim
down to jap bikes that run and a dead Norton |
Flatbutt - May not be the answer you're looking for but from what I've seen there is only one belt suitable for your '99 (like mine) - the P/N that ends in -779. I don't know the physical differences between the two, but the Bob's BMW catalog shows the -779 P/N applicable for Oilheads up to 6/03, then the other belt for subsequent models. It also shows the upper (alternator) pulley changed P/Ns at the same time, but the bottom (crankshaft) pulley stayed the same for all models. Logic tells me the two different upper pulleys may be of slightly different diameter, which would change the belt length, but unless you've changed to a newer upper alternator and/or pulley, you still need the -779 for your '99. I was at Bob's and bought a new belt a couple of weeks ago for my upcoming 36k service, and they sold me the -779 without asking any further questions other than what year my bike was.
Wish I would have thought about this yesterday, I was at Bob's again and would have asked to see both belts side by side for comparison. Next time....
'07 R1200GS Adventure "Brutus" Last edited by jweicht; 12-31-2005 at 05:07 AM.. |
jweicht ; thanks thats good info
Bill; i hardly ever wear underpants let alone pantyhose! cap; good tech info Thanks all!
from memory, the belt from 6/03 on is a 'stretch fit' belt, where the alternator is not moveable and you wind the new belt on using a special tool. i could be wrong, maybe it was introduced later. there's a service bulletin on it anyway.
'89 851 '97 600m '65 Hunnybunny '05 Little man |
I guess removing the pantyhose from the donor passenger would be the best part of that roadside repair.
04 R1100SA (Pacific Blue metalic) 99 R1100SA (black) -- Totalled |
Briefs or boxers... elastic band would be a better alternative including the stretch-to-fit feature. Another reason to wear clean underwear.
jweicht, How much was the new belt?
Dale - Sorry for the delayed response, the -779 belt was $15.39.
Also, I just changed my bike's belt and confirmed that old belt was also the -779 part number.
'07 R1200GS Adventure "Brutus" |
The most time consuming part of this process was getting the alternator cover off. Of course, I already had the gas tank off for other maintenance. Remove the four plastic cover bolts and pull the cover. From the right side of the bike I loosened the three nuts at the front of the alternator and squeezed the belt, which brought the pulleys closer together. Remove the old belt and slip the new one on. Go to the left side of the bike and, using a long extension with a universal joint and the proper size Allen wrench bit (4mm, I think), come in from behind the alternator's lower left side and put the bit into the bolt head and turn it counterclockwise. This will raise the alternator and tension the belt. Holding the proper tension, tighten the three front nuts and you're done. The belt is tensioned properly when you grab it with your fingers at a central point between both pulleys and can just twist it 90 degrees using your fingers. If you can twist it past 90, it's too loose.
Oh, and then you can pop open a brew and admire your work.
