-   BMW R1100S / R1200S Tech Forum (http://forums.pelicanparts.com/bmw-r1100s-r1200s-tech-forum/)
-   -   Streamlined Rear Turn Signals: Need your inputs... (http://forums.pelicanparts.com/bmw-r1100s-r1200s-tech-forum/264092-streamlined-rear-turn-signals-need-your-inputs.html)
Xa3 02-01-2006 10:24 AM
Ok, I have been thinking about making my tail section more streamlined and sleek. I decided that those clunky turn signals would have to go.
So far, I have removed the passenger pegs, slapped Corbin smuggler seat on it, installed Laser exhaust with stealth license plate. Followed with black pyramid rear fender and removed the center stand. It look superb but those darn turn signals really screw up the fine line.
I have decided that I will replace them and install the LED turn blinkers that are reserved for most sportbikes for their front signals. Look at this website: http://www.watsendesign.com/products/current/LEDMINIBLINK/index.html
I want to place them on the tail body near the brake light, right under the seat compartment. I was wondering if you guys have any idea or inputs from your experience of doing the modification. Is it do-able? Is it illegal to use amber LED lights for turn signal in Arizona (and California, I go there all the times)?
If you have done similar mods, please share your pictures... I'm thinking of having the led turn signal be done in black color so the amber light will stand out better during the daytime. My bike is Titanium/Mandarin Yellow 2004 model.
Thanks! -ChaZ
bradzdotcom 02-01-2006 10:38 AM
looks like it'd work.
you'd probably get way with amber lights here in socal.
actually, you don't have to run turn signals at all over here, but you DO have to use arm signals when making a turn within XXX feet of any other vehicles, blah, blah....
plus an AZ license plate in socal gets you off the hook for most everything but doing stupid shiit (more than 80mph in most spots, yellow lines, wheelies, etc...).
ps: i'd go with the 8 light version, rather than the 5.
JonyRR 02-01-2006 11:14 AM
Mine is that way. Looks mucho bettah. pics were posted here some time ago...
pmc847 02-01-2006 12:23 PM
Here you go. No modifications needed.
http://forums.pelicanparts.com/uploa...1138825252.jpg
http://forums.pelicanparts.com/uploa...1138825289.jpg
http://forums.pelicanparts.com/uploa...1138825331.jpg
Philip
"It's a great bike but I can make it better".
04 R1100S BCR # 195
03 R1100S BCR #44 R.I.P. new home with 'onekiwi'
Laser Exhaust
InDuct
SJ PowerFilter
Laser 2 spark Chip
Ohlins
Sargant Seat
Throttle bodies matched to rubber mounts matched to heads
Exhaust pipe welds ground down
Aux Fuel Tank (6.8 gallons total)
1100s nut 02-01-2006 02:04 PM
One more, just to think about Is kellermann from germany. I have them and love them. About the size of your middle finger. Very small and vert bright. Bought mine from the speigler brake line folks. They do not fit the oem holes, slight mod, easy to do.
Lane
Don Shula 02-01-2006 02:10 PM
Bought these from www.r1100sgoodies.com (I think), look very smart but blink a little on the fast side, even with a resistor built in.
http://forums.pelicanparts.com/uploa...1138831804.jpg
John Diakonis 02-01-2006 03:27 PM
I just talked with Ron Watkins at Hyperlight yesterday about what I could do for the back and he said they're comming out with a couple of new products. One called the Sport which will be a combination tail light, brake light and sequential <<<<<<<<>>>>> >turn signal within a very small pachage!
Rapid Dog 02-01-2006 05:47 PM
doh!
Xa3 02-01-2006 10:04 PM
That would ROCK! Did he say when they will be coming out?
-ChaZ
P.S.- And that would require clear tail len. I better get one ASAP before they run out when that new product comes out.
Xa3 02-01-2006 11:28 PM
Took a while to find it, now I understand what you did. You just Kawasized your tail section! *grins*
http://forums.pelicanparts.com/uploa...1118458467.jpg
-ChaZ
HugoVW 02-02-2006 02:53 AM
These are also nice LED's:
http://www.maddoctor.it/fotograndi/Gruppo%20ottico%201.jpg
http://www.maddoctor.it/fotograndi/SPEED_1.jpg
Gets rid of the taillight also;)
Hugo
Xa3 02-02-2006 04:35 AM
I just realized something...
If those Hyper Lite's sport version for our model came out, it would not be functioning because I already installed Kissan running light module. If both turn signals are turned on at 50% intensity as running lights, the turn signals will be doing <<<<<<<<<<>>>>>>>>>> sequences, screwing up my tail light display.
So I've decided that I will go ahead and get that 8 leds turn signal thingy from the website I mentioned above. That way, it will look like running light on the side and on the rear as well for additionaly safety during night.
I will order a pair and I'll take pictures of my project so you guys can also benefit from it.
-ChaZ
ismothegizmo 02-02-2006 11:59 PM
Here's my home made "stealth" bracket with mini diamond blinkers:
http://forums.pelicanparts.com/uploa...1138952638.jpg
From this angle them blinkers are hidden..
http://forums.pelicanparts.com/uploa...1138952907.jpg
One more from the side:
http://forums.pelicanparts.com/uploa...1138953211.jpg
John Lyon 02-03-2006 02:04 PM
I purchased some of those from watsendesign.com and they worked out fine (bolted right to the original spot). I purchased the "Honda" ones, like pmc847. I also installed the optional resistor that slows down the blinking speed to normal (it gets hot, so I zip-tied it in foil before pushing it up inside the plastic bits).
pmc847 02-03-2006 03:17 PM
Here is an alternative. Might be a great addition too.
http://www.culayer.com/ASAP.htm
Philip
Xa3 02-03-2006 05:52 PM
Philip
Hmm, my stealth license plate bracket is placed at an awkward angle (to avoid being nabbed by radar cameras) so I think it wouldn't work on my bike. But it looks great!
-ChaZ
