as Hemingway almost wrote: All Quiet on the Leftest Side
"Wow I'm an idiot, thanks bikerfish!"
Harleys are like opinions, every a-hole's got one!
2001 R11S "lite", with a few mods.
2009 F800GS. has a better saddle. and other stuff. (sold)
2016 R12GSW 3Black. wow.
Old 08-04-2006, 09:31 AM
Dale Flowers's Avatar
I've found that choice of oil effects the noise. The noise was present when I used Mobil 1 but has all but gone away with Rotella T.
'99 R1100SA, ;06 DR650, '84 R100RT
Old 08-04-2006, 01:32 PM
jdlowery's Avatar
I just want to thank markjenn for a good write up. I performed this retrofit last weekend. Everything went smoothly. I started the bike and it is quieter. My ride into to work this morning should give me some more feedback. BTW, a large bent (fish hook style) paper clip lifts the old plunger enough to grab with needle nose pliers and remove.
Jim
'18, Ford F-150; '07, Lexus IS350; '01, R1100S; '80, R65; '76, Honda CB750 Four; '70, VW Beetle; '64, Triumph Bonneville; '55, R25/3
Old 10-23-2006, 07:23 AM
Man it's flat out here!
R111S's Avatar
Thanks...I saved it in MSWord for future reference...
"What I've tried to do in the two books I've done, Signature in the Cell and Darwin's Doubt, is to show just how weak the materialist's hand is in explaining the key events in the history of life. ... We would encourage people to roll up their sleeves, do their homework on this." Stephen Meyer PHD
Old 10-24-2006, 04:11 PM
jgrm1's Avatar
Guys,
The photo of the old and new tensioner on the ADVrider site shows a fourth part new part they call the "smaller floating piston." Mark, why don't you show it in your photo or list it with on your parts list? Did you other guys install this part? Anyone have the part number of this smaller piston?
Thanks,
Jeff
BMW: 2016 R1200RS, 2000 R1100S, 1975 R90S
Ducati: 2008 S2R1000, 1998 900 Supersport Final Edition
Norton: 1974 Commando 850
Triumph: 2016 Thruxton R, 1971 T120R Bonneville
Old 12-31-2006, 08:13 PM
jgrm1's Avatar
After a bit more searching, I learned that the ADVrider parts were superceded by the parts shown in this post.
-Jeff
Old 12-31-2006, 08:29 PM
Re: rh lh
Originally posted by Rapid Dog
weird, same thing here, but I think it only happened once...guess I need to ride it more...anyone else's do the same?
Same here. Can`t figure this one out. It is not nearly as loud as the left side though. It does not do it on every start up. I`m not too worried but I wish it were quite.
Lane
2005 Boxercup, 2013 R1200GS Rallye, 2011 Triumph 675 Daytona, Honda MB5, 2011 KTM300xc, 1975 Bultaco, 1992 Beta, 1972 Aermacchi
Old 01-01-2007, 01:23 PM
lht lht is offline
rt. tensioner
Pull the right side and clean it. Check the spring lenght with the left side. Maybe you can swap them and get rid of the problem that way.
LT
Old 01-01-2007, 01:31 PM
acidburn's Avatar
Outstanding write up.
One more thing to do.
Except for a few cases the murderCycle rate is relatively low on this board, keep up the good numbers.
Old 01-01-2007, 02:10 PM
jgrm1's Avatar
FOR SALE: Original piston, spring, and barrel for left side cam chain tensioner out of 2000 model R1100S. Items are in great shape with only negligible wear detectable. These parts are required for that authentic early R1100S ownership experience of getting knots in your stomach hoping your bike won’t embarrass you by rattling like a can of spray paint at start up (it will). All R1100S owners deserve the opportunity to sheepishly explain this exasperating trait of the boxer engine to all of their non-BMW riding buddies. These items will also be necessary for that concourse restoration in 15-20 years because those anal BMWophile judges will surely detect the 15 mm rather than correct 17 mm bolt pattern on the barrel. Don't lose critical show points. Make an offer today.
-Jeff
Old 01-14-2007, 07:05 AM
Living on borrowed time!
JonyRR's Avatar
WTF????
I don't have that floating piston.
A&S never mentioned it to me when I bought the upgraded parts.....
Better a has-been than a wanna-be
'I am John Andrew Moffett of the Clan Moffat and by god I live, love, seek, fail, grieve and die as I so choose and I call no man master save me'.
Old 01-14-2007, 10:43 AM
Reread this thread...
- Mark
Old 01-14-2007, 04:58 PM
I just did this mod on my R1150R. Nothing but happiness. Easy too.
I did not have the throttle body O-ring on hand, and I wish I did when I got into it. The stock one was enlarged (just like Mark warned) and it was difficult to fit back into place properly.
A throttle body sync with a twin max et al afterwards should show an out of balance condition, which is probably air leak, if you get it the o-ring back on wrong.
Old 01-14-2007, 05:32 PM
JonyRR's Avatar
mj;
I did..I'm dyslexic...however, nowhere did I see that 4th part in the illustration/circled above.
Old 01-14-2007, 05:58 PM
IIRC, it all comes as a single piece.
Old 01-14-2007, 07:37 PM
Originally posted by JonyRR
mj;
I said "read" not just "look at the pictures". READ my original post or the post after the picture you're worried about.
- Mark
Old 01-14-2007, 08:01 PM
acidburn's Avatar
Cmon guys make it easy for me i want to get the set up too.
Old 01-15-2007, 07:34 AM
mj's first post has it all. done.
Old 01-15-2007, 07:52 AM
Okay, one last time, now pay attention.
The picture below is OBSOLETE. As discussed here and in the Advrider threads, the "Upgrade Model" parts below are part of a $250 discontinued "kit" from BMW that is no longer available.
This picture is CURRENT AND CORRECT. The tensioner parts at the bottom are what need today. As a bonus, they're much cheaper ($55 or so).
11317688629 - cylinder
11317656922 - piston
07119963308 - seal ring 18x22
AFAIK, my original post here and my follow-up posts on Advrider are current and correct. That was the whole idea of this thread - to cut through the confusion and say exactly what you need to do on the S with the latest parts. Obviously, I failed miserably.
- Mark
Old 01-15-2007, 09:43 AM
i dunno, it worked real nicely for me when I did mine MJ. thanx. and fwiw- the job was much easier than i thought it would be.
Old 01-15-2007, 09:56 AM
