Talk Less, Say More
ckcarr's Avatar
Location: Moab Utah. Home of wierd red & orange radioactive stuff... And 1 billion tourists.
For those with air compressors
What kind of air tools do you find consistently valuable?
For both bike and other vehicles??
cRaIg CaRr
2000 Dyna FXDX, 2001 Sportster Sport, 2000 R1100S,2007 R1200S,2015 rNineT,2023 F850GS,2023 R1250RS, 2017 Triumph T100, 2019 Jeep Rubicon, 2005 Jeep Sport, 2001 Corvette, 1978 Porsche 928. 2001 GMC Sierra 2500HD, 22 pairs of shoes. 24 bottles of beer.
Old 02-27-2006, 10:36 AM
mullerjd's Avatar
Air chuck is probably #1. Blow gun nozzle, air ratchet, impact gun, and a few others I have only get occasional use.
05 BMW R1100S BCR, 87 BMW K75C, 69 BMW R60US, 63 R69S sidecar project, 02 Suz SV650S, 01 Suz SV650S, 00 Suz SV650 naked, 01 Suz TLR fighter, 05 Suz DL650, 98 KTM 380 MXC
Old 02-27-2006, 11:31 AM
Air Chuck #1. Handy Lift #2. Twice a year I use my 1/2" impact gun to remove the 18" alloy wheels and F-1's from my GLI, and mount 16" steelies with snow tires (my wife calls them ghetto wheels). Getting ready to remount the nice parts. Very rarely do I use the 3/8" "flapper" impact gun.
Old 02-27-2006, 11:36 AM
unsafe at any speed
wswartzwel's Avatar
Add to Mullerjd's list
Die grinder with various burr bits, scotchbrite roll locks, and cut off wheels
Bill Swartzwelder
Old 02-27-2006, 11:38 AM
Barback King
Rapid Dog's Avatar
....On Topic, who's got a fullsize bike lift, where are the best deals...opinions plaese...
R11S CNC BARBACKS
Old 02-27-2006, 11:39 AM
itchybro's Avatar
How bout a horn? I mean it wouldn't be terribly mobile but wow, it would NEVER run out! Be a hit with the kids!
(Pardon me, I got horn on the brain for some reason)
The pioneers had a hard life but,
sometimes someone would break
out a fiddle....And make it worse.
Old 02-27-2006, 11:40 AM
roger albert's Avatar
Strangely, some of the simple ones.
Besides a tire chuck, a rubber tipped blow gun is great for cleaning surfaces and blowing out passages and chasing away the neighbor's cat or making your nephew giggle.
An impact driver for breaking bolts loose is great. Even the fairly cheap ones (mid range of harbor freight etc) are OK initially. They just don't hold up as well. But if the use is infrequent, they're OK. If you'll use one more, get a big namebrand one. It will last forever and deliver a big more peak torque. That's more important if you have a compressor with low deliver or peak pressure (125 or 150 instead of 175)
A good rule of thumb is that if the tool has a 90degree mechanical linkaage (bevel drive etc) then get a really good one. Simple vaned or reciprocating things (sander, buffer, drill, file, etc) do ok even if on the el-cheapo side.
I'd get a good 1/2 drive impact gun and decent 3/8 air ratchet.
Often overlooked is when you need to drill in a tight space. A decently powered 90degree drill (Milwaukee etc) is over a buck-fifty, and is still not that small. A cheap HF one can fit in tight places and is like 30 bucks. Not tons of peak torque, but not bad, given they're geared down.
Cheap orbital sanders seem to break all the time. To be avoided.
A die grinder for grinding stones and cutoff wheels is indispensible.
Get a 3 or 3-1/2 inch. HF ones are ok. In fact, get two or three when they go on sale at HF. Youll end up with plenty spare stones/bits (which you'll always find use for) and you can set up one for each collet size, saving a bunch of changeover time when dealing with bits with different shank diameters.
So, in order, imo
tire chuck
blowgun
die grinder
1/2" impact gun
3/8 ratchet (good for poly bolted flanges/covers (rear drive, clutch etc)
airfile and/or air saw (work well where there's not enough room/stroke for a manual one)
And a tip. On a motorcycle, airtools are only for removing, if used at all.
replace by hand.
hth
99 R11S w/ BBP, InDuct, Öhlins, PVMs, Braking, SJ-Filter, ZTech, HIDs
D675 R90Cafe R60/2 M900 SV650-SS CBR150R XR125 & CRF175 Motards
OnRoad OffRoad Cycles, Austin, TX: BMW, Ital, Suspension, Electrics
Dealer for K-Tech, JRI, GP Suspension, Penske, Öhlins, RaceTech, Elka, Wilbers, IKON & Works
www.ororcycle.com
CMRA EXPERT #841
Various Formula 5, 6 & 7 championships 2006-2012
A3, Navigator,
Old 02-27-2006, 11:41 AM
unsafe at any speed
wswartzwel's Avatar
QUOTE]Originally posted by itchybro
[/QUOTE]
My wife tells me I always have that on my mind too Itchybro.
Bill Swartzwelder
Old 02-27-2006, 11:42 AM
mullerjd's Avatar
I've got the Harbor Freight one.. it's not air powered but as much as I use it, I didn't need that option. I got a cupon off the net somewhere so it only cost me $249..
Old 02-27-2006, 11:45 AM
Barback King
Rapid Dog's Avatar
...thise aren't air operated are they? Tell me more...
R11S CNC BARBACKS
Old 02-27-2006, 11:56 AM
mullerjd's Avatar
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=91764
Old 02-27-2006, 12:16 PM
Talk Less, Say More
ckcarr's Avatar
So I'm asking because I found a returned new compressor at Sears for 1/2 the sale price and bought it. Its a 3 1/2 horse 15 gallon. Will that be enough for most basic work?
cRaIg CaRr
Old 02-27-2006, 01:21 PM
unsafe at any speed
wswartzwel's Avatar
Yes that will be good.....If it is a real 3 1/2 Horse you can even run a small sandblaster with it!!! Some of the newer ones throw HP numbers around though that are misleading.
Bill Swartzwelder
Old 02-27-2006, 01:29 PM
Biggest Member
gigantic's Avatar
Send a message via AIM to gigantic Send a message via Yahoo to gigantic
it should be enough to inflate tires and blow bits of dirt & dust, as well as use nailers & such but not likely enough for impact guns, air ratchets and die grinders.
Old 02-27-2006, 01:36 PM
unsafe at any speed
wswartzwel's Avatar
??? I used a 3.5 HP Sears 2 stage air compressor to sandblast my 40 dodge business coupe project... and it kept up fine??? It was a 2 cylinder 2 stage pump. but it was made 17 years ago before they changed the meaning of horsepower
This one runs 4 mechanics, bead blast cabinets, and a used oil furnace and it is only a 5hp compressor.....
Bill Swartzwelder
Old 02-27-2006, 01:41 PM
Talk Less, Say More
ckcarr's Avatar
If its not good enough for impact guns why do they give you one with it?
cRaIg CaRr
Old 02-27-2006, 01:53 PM
unsafe at any speed
wswartzwel's Avatar
Whats the model number.... Does it have a CFM rating?
Is it a real compressor with pistons and a oil crankcase, or one of those little pancake things that contractors use to shoot nails with?
Bill Swartzwelder
Old 02-27-2006, 01:55 PM
I have a full-size Handy Lift, works on air. I bought it when I got my LT (800#). Wouldn't trust anything less with that much weight. Now I use the Handy to work on the "S" and also on my Norton. It is a very stable work platform and can be raised to various heights, and locked in positon. It was about $900.
Old 02-27-2006, 02:13 PM
Bob in Tucson's Avatar
Most compressors can drive most air tools at least for a short time, but for high air-demand tools, they will recycle constantly and not be able to keep up. Trying to run a RO sander on a small compressor, for example, would be torture.
As wswartzwel said, check the air demands for the tools you're interested in and then the delivery rate for the compressor.
For typical hobby use, I think you'll be just fine.
Old 02-27-2006, 02:34 PM
kpoling's Avatar
OT Air compressor
Check the CFM rating at a stated PSI: 10CFM @ 80PSI.
The HP ratings on small air compressors is a B.S. way of rating.
Like others have said, look at the air consumption @ xxPSI of the air tools you want to use & that will size your compressor.
The air tank just allows a few extra seconds of air if you are using more CFM than the pump puts out.
Most home compressors are rated at less than a 50% duty cycle.
All that said, I use an Emglo wheel barrow style contractor 1-1/2HP, oil type. It will run my 3/8" ratchet & impact. It barely runs my 1/2 impact. If money was no object & I had the room, a 7.5HP, 2-stage w/60gal tank would run most common garage tools at around 20-22 CFM @ 80PSI.
Kevin
2000 R1100SAL Yellow/Silver - SOLD July 2008
2002 R1150 ADV
2000 Kawasaki W650
Old 02-27-2006, 02:58 PM
