pluggin it
JRR, It's the S I was riding that has the 1031 box, and getting
sucky mileage. I posted on the Techluison forum and this was the answer: "Performance is never free. You always have the option to back down the adjustments until the performance level is 'just' acceptable. I suggest you turn off the yellow and red fuel and try running on the green alone." ...so that is what I'll do, turn off the R&Y pots. It's the low RPM I installed it for anyhow (Green pot). The mid and high range RPM (R&Y pots) have to be where it's sucking the extra fuel. BTW JRR, I did the valves TBS synch then the TPS voltage set procedure just before installing te 1031....'member? |
| All times are GMT -8. The time now is 09:22 AM. |
