Ride Far - Ride Fast
Dan Alexander's Avatar
OT: ducati fork seal help
Hey there o wise ones of PP ,
I'm going to help a friend change the fork seals on a 2003 ST4S with Showa forks. Anyone done these before, do I need any special tools?
Tia
74 R90S, 77 R100RS, 85 K100RS, 2-87 K100RS
99 R11S
2002 Blue and White GS ... the prettiest
2008 KTM 950 Super Enduro long distance gravel road and general hooligan bike.
Now an R11GS and a 650 Dakar
Old 05-02-2006, 05:50 AM
If they are the same USD Showas that the Futura uses you can get by if you have a well equipped garage. I break everything loose while the forks are still clamped in the triple trees & then pull them off & work on the bench. Be sure to rinse out the internals & drain well so you get an accurate measurement when refilling. Follow the procedure for bleeding air in the service manual if you have one if not I can send you the info in the Aprilia manual.
John B.
03 R1100S Prep(wife's), 02 Futura, 92 907ie, 89 Transalp, 87 R80/100, 82 Morini 3.5 sport, 76 R90/S, 73 R75/5
90 535im & 95 525i Touring
65, 66 Alfa Romeos
Old 05-02-2006, 06:29 AM
I don't have any manual for the bike. The service dept. tell my friend that you need some kind of a puller?
99 R11S
Old 05-02-2006, 07:25 AM
