mo' PCIII talk, yo...
so in my data collection of throttle position and RPM to see where i most commonly run when cruising, i found that i sit roughly at 50% thottle and around the 3500-5000 rpm range.
now the question, the PCIII map is set up at 0, 2, 5, 10, 20, 40, 60, 80, and 100% throttle...so what is happening at 50% throttle? also, the "promote to advanced map" appears to be a map for each injector? also, what is the duty cycle and fuel change represent? repoe3
I couldn't repair your brakes, so I made your horn louder. 2009 GSXR 750 2004 Tuono 2004 R1100SBX |
Re: mo' PCIII talk, yo...
It Interpolates all the data from the other positions. [/QUOTE] also, the "promote to advanced map" appears to be a map for each injector?[/QUOTE] Not on the BMW's. Other "normal" bikes have a map for each cylinder. [/QUOTE] also, what is the duty cycle and fuel change represent? Duty cycle is the Fuel Injector "duty cycle" how hard it is working. Fuel change tells you how much more (or less) fuel is being delivered by the PC. repoe3 [/QUOTE] |
thanks for the quick response.
repoe3
