No try, do or not do
shreddr's Avatar
R1200S cannisterectomy
Has anybody performed this "surgery" on their R12's. I want to do some suspension tuning, and I see it is right in the middle of any potential front shock adjustability ease.
2017 R1200GSW Rallye Shreddr Signature Model
Old 11-11-2007, 04:42 AM
Uh....who me?
Bob Hancock's Avatar
I saw mine done....pretty simple. The only "trick" is there's a nut that must be got to in order to remove the bracket. It's on the left side behind what looks like a computer thingie that can be pressed out by hand. (It's called the Central Vehicle Electronics Control Unit). The maintenance manual says, "Carefully pry open clips and lift the control unit forward to remove, taking care not to disconnect the plugs." Once you get the tuppeware off and look at it, it should become pretty obvious. HTH.
Bob Hancock
'20 KTM1290 SuperAdventure S, 2006 KTM 660RFR Dakar, 1966 Honda 305 Scrambler, 2019 Camaro 2SS 1LE, 2020 Chevy Trail Boss
"There are times when good words are to be left unsaid out of esteem for silence." St. Benedict
Old 11-11-2007, 06:21 AM
