Oil Sight Glass Removal
Well it's seeping and just in time for an oil change so I have to change it out. I checked the archives but need a presice procudure. Is it as simple as a wood screw and yank it out and pop the new one in.What should I be careful of? Thanks, John
Old 09-11-2006, 02:29 PM
Flatbutt1's Avatar
The screw method is what I've been told to do. Be careful about not getting any glass bits inside the hole, wear clean underwear and always use a condom.
big blue tricycle
stare down the darkness and watch it fade
Old 09-11-2006, 04:07 PM
I pulled mine out with a set of tool grade dental picks, cleaned the area well, and drove the new one in with a socket that was the same size as outer rim, forget what size.
99 Black r11s
02 klr 650
03 zrx 1200
08 thruxton 900
82 ascot 500
Old 09-11-2006, 05:06 PM
When you drove it in did you use a rubber mallet or hammer, I've read where the rubber didn't drive it in far enough, would bounce instead of driving it in?
Old 09-11-2006, 05:31 PM
roger albert's Avatar
Either will work. May have to whack a tick harder with a rubber
99 R11S w/ BBP, InDuct, Öhlins, PVMs, Braking, SJ-Filter, ZTech, HIDs
D675 R90Cafe R60/2 M900 SV650-SS CBR150R XR125 & CRF175 Motards
OnRoad OffRoad Cycles, Austin, TX: BMW, Ital, Suspension, Electrics
Dealer for K-Tech, JRI, GP Suspension, Penske, Öhlins, RaceTech, Elka, Wilbers, IKON & Works
www.ororcycle.com
CMRA EXPERT #841
Various Formula 5, 6 & 7 championships 2006-2012
A3, Navigator,
Old 09-11-2006, 06:05 PM
Uh....who me?
Bob Hancock's Avatar
And a good reason to go out and buy a dead blow hammer. Perfect for these kinds of things.
Bob Hancock
'20 KTM1290 SuperAdventure S, 2006 KTM 660RFR Dakar, 1966 Honda 305 Scrambler, 2019 Camaro 2SS 1LE, 2020 Chevy Trail Boss
"There are times when good words are to be left unsaid out of esteem for silence." St. Benedict
Old 09-11-2006, 06:39 PM
Did it! Heated a screw to melt into the plastic. Broke the plastic and ended up prying it out with a screw driver. Hammered that sucker in and changed my oil. Not too bad. Changed out the clutch fluid while I was at it too. Thanks for the tips everyone.
Old 09-12-2006, 08:42 PM
