Registered felon
BMW Atlanta and others...
There has been more than a few people that have questioned wether raising the tubes up in the clamp, say to put the bars up top, will change the geometry and handling of the bike. I have to say I do not know. One member claimed that the BCR fork tubes where longer than the standard S....I'm not so sure that's true. The sliders (male) are purely neutral as far as length vs geometry goes from what I understand. I ay be way off here. Your thoughts...
S-less old fool/'05 R12GS/AssChaps/'06 Orange Thang CNC Machined R1100S BARBACKS n' stuff... ...een snelle hond is moeilijk te vangen ; hij hangt zo soepel aan het gas! Last edited by Rapid Dog; 10-08-2007 at 09:10 AM.. |
Re: Raiding Sliders vs Geometry
Fork tubes/stanchions werent longer if I remember correctly but the bike sat taller due to a longer sport front shock with stiffer spring vs standard sport shock and standard shock. So BMW actually has 3 front shocks available for the Boxer cup with 2 variants of the front sport shock.
Bobby BMW Ducati & Husqvarna of Atlanta 06 HP2 SM, Akra Ti, RapidBike3, |
Registered felon
...as I assumed.
But the other question, does actually moving the sliders affect the actual geometry...any idea?
S-less old fool/'05 R12GS/AssChaps/'06 Orange Thang CNC Machined R1100S BARBACKS n' stuff... ...een snelle hond is moeilijk te vangen ; hij hangt zo soepel aan het gas! |
NO, it has NO effect whatsoever.
That's been well established for several years now, and pretty well established since before the S came out. I don't think there have been more than a few questioning it, and they were all quickly set straight. You're on the right track rapid, albeit not too rapidly ![]()
99 R11S w/ BBP, InDuct, Öhlins, PVMs, Braking, SJ-Filter, ZTech, HIDs D675, 76 R90Cafe, 65 R60/2, 94 M900, 89 Hawk, SV650-SS, SV650-Sbk, XR125 & CRF175 Mini Motards OnRoad OffRoad Cycles, Austin, TX: BMW, Italian, Suspension, Electrics Dealer for Öhlins, Penske, Elka, Works Performance & RaceTech www.ororcycle.com CMRA EXPERT #841 09 F6 3rd overall 08 F5 Endurance Champs, F6 Champ, & F5 2nd 07 Formula-7 & Formula-6 Champ 06-07 F7 Endurance Champs 00 Navigator, 86 Porsche 944 |
Registered felon
...jus' checkin', I got a guy who axed the question that's all...he'll be joining us soon..
short of taking the slider a few inches out of the forks there are no ill effects. One could go overboard and slide the tube 3"+ up and take away alot of rigidity in the leverage aspect and cause some flex shudder under heavy braking because there wouldnt be enought tube in the forks to disperse the load so they would flex more.
Quite the evangelist there Rapid!
Registered felon
...i like to think of myself as a shepherd for wayward and the weary...
Anyone got side-by-side pics of raised/non-raised tubes? To see the non-effect?
aka Rev Z-Man -- click http://www.bmwforums.net for a good time. - 2001 BMW R11SA Dakar Yellow/Night Black - 1998 KTM 300 EXC - ORANGE! - 1995 Triumph Daytona 900 (For Sale!) - 1985/86 GSX-R 750 (Track bike in progress) |
Think of it this way, You could push a broom with a 4' handle or an 8' handle but chances are you are still going to push the broom the same either way and one's just going to have a longer handle. The clamps are fixed in relation to the frame as your hands are to your shoulders. Makes no difference how much slider is hanging out in reference to ride height or rake/angle.
I hear you guys talking but I don't see anything other than typed-out "proof". I don't usually believe EVERYthing that I read on the Internet. Not sure why everyone is so adamant about not actually, visually proving (or disproving) the geometry.
ride on over and I will gladly show you in person on the showroom floor with angle finder and tape measure.
Banned
Here's a way to look at it: if you can raise one stanchion at a time while the other is locked in place, this would prove the geometry hasn't changed. Try it and I think you'll join the majority viewpoint. A well-known wrench from Pennsylvania wrote me that he has ridden with the S stanchions raised 4 inches to ease back pains. Not sure if this was a long and careful trial or just brief ride but the souce is trustworthy. |
Well said Peter. Very good explanation.
Heck, from a geometry standpoint, you could REMOVE a stanchion, or even both. Wouldn't budge the wheel vs frame, which is pretty much the definition of geometry. But damn, this is a darn simple system with everything out there in the open. You only have to look at your bike for about 30 seconds to prove it. I can see how the uninformed (all of us, to greater/lesser degrees) could debate ECU control algorithms, but this? What's not to see or understand???
I wanna Live 'til I die!
>>>Fair enough to be skeptical about accepted wisdom.<<<
...kinda reminds me of a guy who insited that German car companies don't close their productionlines in august! ![]() I am searching for static diagrams on that topic, hev not found any yet...
Ralf Wilkowski The only reason some people get lost in thought is because it's unfamiliar territory www.itwasnotme.com 1985 Yamaha XT600 - 2000 Suzuki DR-Z400S - 2001 HD Sportster 1200S - 2005 R1200GS |
ErricZ
On conventional forks you move the fork up (or down) using both top and bottom triple clamps thus moving the frame and motor up or down. On the BMW you only move the tubes using the top clamp only, thus not moving the frame. The only way to move the frame on our bike is to change the length of the shock (same as forks on conventional). Now, if you could move the big tube up or down in the bottom clamp then you would be moving the frame but you can't because the tube is machines to fit the clamp and can not be moved. Simple. Philip |
Living on borrowed time!
well, you can argue endlesslyy and (mastur)debate this endlessly, but the fact is this front end IS NOT!! a stanchion/slider 'convnetional' front end. I didn't believe it myself until I looked closely at the measurements.
The ONLY thing that sliding the fork 'stanchion' tubes up does is to, as bobby said, reduce the internal overlap of stanchion and 'slider'...which, I suspect, if the 'stanchions' came far enough out, would produce some rocking motion as the internal engagement surfaces are shorter. Mine ARE out at least 3" and that's the ONLY reason I have been cosnidering longer 'stanchions' from Forking By Frank...to regain the internal overlap. I can feel it. But as far as changing frame or steering geometry, it does not...not one whit. RAISE the front shock via shims under the top mount and measure the wheelbase befoe and after...you'll get a surprise as the OEM-VS-raised measurement will not be in the direction that conventional thinking says it should. Unlearn everything you thought you knew about conventional forsk when dealing with telelever. Wanna really cook some brain cells...throw conventional-fork thinking at a new K bike ...you'll have to drink a BUNCH ot tequila to unscrew your brain from that one
Better a has-been than a wanna-be Injection is nice but I'd rather be blown bottles are not just for babies..... 1999 R1100S;1999 KTM 380EXC street-legal motard WASCO-framed XR883 (ex Natl#25 Todd Bowne's) |
Thread Killer
I like to use a fork instead of chopsticks at Chinese restaurants. Don't know if that's helpful or not.
07 R1200S Black |
So given the geometry stays the same, what changes, if any, happen to a bike's handling with different handlebar setups: low/BCR, middle/SA, raised/Barbacks &/or Wunderlich triple handlebar clamp w/1150R bars, e.g.?
Ride Safe, Saint '02 R1100S - sold '89NX250, '98FLSTF, '07 R1200GS |
Hey, Erric... I've tried to draw something rather quickly, I hope this will explain it...
