-   BMW R1100S / R1200S Tech Forum (http://forums.pelicanparts.com/bmw-r1100s-r1200s-tech-forum/)
-   -   O2 sensor removal (http://forums.pelicanparts.com/bmw-r1100s-r1200s-tech-forum/306349-o2-sensor-removal.html)
lht 09-25-2006 06:09 PM
O2 sensor removal
Anyone know what size plug to use and where to get one? I want to remove mine for awhile. I just installed a San Jose Duct kit.
Thanks Lance
wswartzwel 09-25-2006 06:12 PM
rumor has it that JonyRR is using a spark plug... something he learned in the 50's when doing flame throwing contests
http://splparts.com/Parts/Universal/Hardware/Fittings/default.asp
has plugs to fill the hole... scroll down. $8
Anton 09-25-2006 07:02 PM
Why not use the O2 sensor to plug the hole, it screws right in, no need to plug it in.
lht 09-25-2006 11:02 PM
Leaving it in will just soot it up and kill it. Taking it out will be less of a restiction in the exhaust and I will gain 10 H.P. (G).
wswartzwel thanks for the info.
JonyRR 09-26-2006 09:29 AM
K&N makes a special bolt just for this...also the car accessories folks like holley or something. try a local car spped shop, and you do NOT want to leave the 02 sensor in but unplugged, as you will ruin it, as has been pointed out.
Bill, I run the K&N plug when the 02 sensor is out.
madman 09-30-2006 10:45 AM
Is there anything to be gained by disconnecting the O2 sensor on a bike with standard air filter, but no catalytic converter?
Boybiker3 09-30-2006 11:05 AM
Might be a good thing to do. This is one person's tests about what happens to A/F ratio with the sensor removed. But there's newer information about the PC III on a thread in the BMWforums.
http://tinyurl.com/6bvt23
JonyRR 09-30-2006 02:17 PM
my original tune setup worked great before I went to a PCIII (the pc is there baecause I intend to do MAJOR mods, like a 1200C crankshaft, 1136 cylinders, massive headwork and different cams)
try this setup:
do a 0=0 TPS dialin as described in the lentini/dr. curve PDF (it's around here somewhere)
yank the 02 sensor.
yank the CCP (Cat code plug)
NGK BKR7EA plugs (honda cycle part#)
that setup is cheap, reverseable and I found it to make my scoot run mucho better.
this is for an early model single spark machine.
on a twinspark, I have no idea, as I don't own an OEM twinspark.
