LinkBack | Thread Tools | Rate Thread |
Brembo brake pad replacement on '99
Man it's flat out here!
Your close Sideshow_S but not quite there...I assume you're talking about the Front Calipers?
The pins are not threaded...the blade hole is used to rotate it into position for easy clip install. I re-bolted the Caliper to the Fork and then used a small punch to drive the pin out from the other side...be sure to put a very light coat of Anti-Seize compound on the pin before re-assembly.
"What I've tried to do in the two books I've done, Signature in the Cell and Darwin's Doubt, is to show just how weak the materialist's hand is in explaining the key events in the history of life. ... We would encourage people to roll up their sleeves, do their homework on this." Stephen Meyer PHD |
Cool! Thanks, R111S!
Thread Tools | |
Rate This Thread | |
