Go Back   Pelican Parts Technical BBS > 2- BMW Forums > BMW Technical Forums > BMW R1100S / R1200S Tech Forum
BMW Atlanta's Avatar
Send a message via AIM to BMW Atlanta Send a message via Yahoo to BMW Atlanta
Dyno'ed at 100+ rwhp today
Well, I haven't tinkered with the R11S much lately with the HP2 glimmering in my eye and the New Remus Race system I put on the HP2 (wow what an improvement). But after a track day last month at Barber I decided I could still do plenty with the old girl. Took her up today for a dyno run at lunch to get a baseline before I decided to order a PC III based on the exhaust readings. I was surpised as well as our old lead tech Zach to get 100.75 RWHP at 8k RPM with a peak torque of 72.22 at 6200 RPM. We also dynoed a seasoned 2000 R11S with exhaust and chip earlier in the week at 90 RWHP, so the dyno is well within average range. Based on the exhaust analysis I could definitely benefit from the PC III, so it will get ordered today and on it will go to see if I can find 2-3 HP and smooth out the curve that much more. I have had crazy thoughts of doing an 1150 high compression long rod conversion with re-valved/ported heads, but I have to see what's coming over winter before I commit to such an expensive overhaul when my OEM setup is as good as it has ever been at 26k miles and all that money for such an overhaul would go along way to procurment of a new steed if it appeals to me.
Bobby
BMW Ducati & Husqvarna of Atlanta
06 HP2 SM, Akra Ti, RapidBike3,
Old 10-06-2006, 10:21 AM
EZ-RIDER's Avatar
well pretty good hp results, I have istalled 1150 clyn. and pistons and cams and running around 110 to 112 rwhp, wanted to go the long rods but
had a hard time finding them.
Dyno'd 104Hp 74.3 ft lbs torque at the rear wheel
1150 cylinders 12:1 pistons/ race cams, Lennies induct, Laser Boxercup II Exhaust, Ohlins shocks, Dymag Carbon Fiber Five Spoke wheels, Crossover tube removed, heads ported and polished Bigger valves installed intake and exhaust! SJ power filter, motoyoyo clamps , HID
Old 10-06-2006, 11:25 AM
turnerm's Avatar
Send a message via AIM to turnerm Send a message via Yahoo to turnerm
How much HP at the crank to dyno 112 at the rear wheel? Sounds like quite an increase.
2008 R1200GS Blue
Gone: Suzuki DR-350, 1998 F650, 1999 R1100S, 2000 K1200RS, 2000 Ducati 996, 2002 R1150RS, 2007 R1200S silver/red
Old 10-06-2006, 02:00 PM
Living on borrowed time!
JonyRR's Avatar
the route to 110RWHP is filled with cylinderhead work, compression increases, displacement increases, in E-Z's case, cams made a BIG difference, right, EZ?
As I understand it, carillo makes long rods for the 1100/1150 R259 engine, but of course, that takes a piston with the pin hole further up, almost into the bottom ring land....but they ARE carillo's
Better a has-been than a wanna-be
'I am John Andrew Moffett of the Clan Moffat and by god I live, love, seek, fail, grieve and die as I so choose and I call no man master save me'.
Old 10-06-2006, 02:32 PM
EZ-Rider
You running the SJ big bore kit??
Old 10-06-2006, 05:00 PM
turnerm's Avatar
Would it be wrong to assume that 113 wrhp translates to over 130 hp at the crank?
Wow, you made a better engine that BMW did with the R1200S!
2008 R1200GS Blue
Old 10-06-2006, 08:16 PM
The loss is normally given at 8hp, so 121hp at the crank.
http://www.bbp.homepage.t-online.de/r11s4e.htm
But this diagramm shows 132hp at the crank (or124rwhp) is possible:
http://www.bbp.homepage.t-online.de/r11s5e.htm
Hugo
Old 10-07-2006, 04:30 AM
I have been wanting to utilize BBPowers goodies for the past 3 years, and now that I am at a point to afford it I think I want to wait and see what's new before throwing $3-4k at an $8k bike.
Bobby
Old 10-07-2006, 05:13 AM
Thats why i asked the question about who's big bore kit was used,SJ's or BBP's
Old 10-07-2006, 06:57 AM
EZ-RIDER's Avatar
I purchased the parts myself separatly pistons are 12:1 1150 clyn. had chris, Machice them to fit the case, I did not use San Jose Kit because he uses stock pistons.Before the mod I was pushing 102.7 rwhp So I gained 10 hp
Old 10-08-2006, 11:44 AM
Moybin's Avatar
I remember that the early 1994 R11RS had larger intake valves. Don't mean it's true, just what I remember. Maybe BMW Atlanta can tell from the parts listings? You need to move more air as well as fuel if you want to make more HP.
'99 Black SA "OBSSSN" - gone but not forgotten.
Not all good technology is new, not all new technology is good.
.........Purple is Satire.........
Old 10-08-2006, 04:37 PM
don't forget that the engine becomes more efficient in regards to air and fuel with higher compression. BBPower is making 132hp at the crank with modified heads, valves, and throttlebodies but no mention of bigger injectors.
Bobby
Old 10-09-2006, 05:30 AM
Copyright 2018 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
