Go Back   Pelican Parts Forums > 2- BMW Forums > BMW Technical Forums > BMW R1100S / R1200S Tech Forum
No try, do or not do
shreddr's Avatar
Chip or no chip
i know this topic has been discussed ad-nauseum, but here i go. do i need to replace the stock "chip" (motronic bit?) in order to realize some real performance gians (ie SOP: seat of pants) im not interested in dyno charts, or what gets me 3 more HP from 6500 - 7000 rpm, do i need the chip to realize a recognizable performance gain for a street rider. i have a stock motor with the exception of a cat eliminator and Laser cans. I am sure there are lots of opinions, and lots of previous questions (no moderator search admonitions please) thanks
2017 R1200GSW Rallye Shreddr Signature Model
Old 10-15-2006, 02:07 PM
foobeemer's Avatar
Why didn't you get a Laser chip when you got your cans?
Chris
'02 R11SA
'07 K12R Sport
Old 10-15-2006, 02:11 PM
tm1100s's Avatar
shreddr, get the Laser chip for the cat eliminator (laser sport collector) and the Laser cans from Mr. Foster. You will notice the difference.
tm
(R12, R11, R1) + 00 then S, S, /7
Old 10-15-2006, 02:43 PM
shreddr's Avatar
can anyone clearly quantify the benefit of the chip?
Old 10-15-2006, 05:53 PM
John Lyon's Avatar
In spite of having the Laser cat eliminator, I haven't done the chip, and my bike starts and runs fine. However, it was explained to me that I may be running too lean without a chip and I may be taking a chance. It was also explained to me that to clearly quantify the benefit/need, you need to go to a dyno which measures the fuel mixture at various rpms (which you don't want to do). Fixing the mixture will obviously make it run better and perhaps prevent damage, which may or may not be "feelable" through the seat of your pants.
2010 MG Griso 8V
2000 R1100S (retired)
Old 10-15-2006, 07:18 PM
Banned
You can't check Motronic 2.4 A/F on a dyno using the usual fourth-gear acceleration runs (or set a PC III for that matter) because while accelerating and for seconds after, the Motronic avoids closed-loop fueling (which tends to be leaner than Alpha-n fueling).
Measure A/F directly and under load under representative driving conditions.
A lot of PC IIIs have been set up by means of screwy dyno tests because dyno guys don't always know or care how a Motronic works.
Old 10-16-2006, 06:33 AM
EZ-RIDER's Avatar
Instead of getting a chip, I would go with a power commander!
Dyno'd 104Hp 74.3 ft lbs torque at the rear wheel
1150 cylinders 12:1 pistons/ race cams, Lennies induct, Laser Boxercup II Exhaust, Ohlins shocks, Dymag Carbon Fiber Five Spoke wheels, Crossover tube removed, heads ported and polished Bigger valves installed intake and exhaust! SJ power filter, motoyoyo clamps , HID
Old 10-16-2006, 07:06 AM
Or a Technlusion which is easy to set up and half the price.
Works very well on our GS with Two Brothers,teenie bit loud but the throttle wheelies are fun.
Old 10-16-2006, 11:14 AM
Raven's Avatar
Been there done that, the PCIII works much better.
Donít believe everything you think!
I don't suffer from insanity, I enjoy it!
2000 red R1100s, 1983 Gold Wing Aspencade, 2003 CRF450R, 1996 KLX 650, 2006 Ford F250 super crew long bed
Old 10-16-2006, 06:09 PM
John Lyon's Avatar
Originally posted by Boybiker3
You can't check Motronic 2.4 A/F on a dyno using the usual fourth-gear acceleration runs (or set a PC III for that matter) because while accelerating and for seconds after the Motronic avoids closed-loop fueling
Don't know much about this stuff, but can you overcome this issue by holding the rpm's steady at various steps (like every 500 rpm or something?
2010 MG Griso 8V
Old 10-16-2006, 07:03 PM
