Go Back   Pelican Parts Technical BBS > 2- BMW Forums > BMW Technical Forums > BMW R1100S / R1200S Tech Forum
induct/power filter install
Just bought an InDuct(?) and power filter kit from San Jose BMW. Getting the plastic snorkel unit on has me scratching my head. Very tight against the battery. Looks like the battery has to be pushed forward a little. Don't want to break anything. The instructions don't address the tight fit. Any install tips/observations appreciated.
Old 10-27-2006, 05:40 AM
  Pelican Parts Technical Article Directory    Reply With Quote #1 (permalink)
Dismembered
GotRoad?'s Avatar
I have this set-up..it will fit, just ease it on. You might want to add an adhesive-backed rubber pad in a couple of spots to keep the inside of the bodywork from getting too scratched-up from rubbing on the snorkel. You might also want to trim off excess flashing near the airbox area.
farkled '04 R1100S SOLD!
2012 Ducati Multistrada Pikes Peak (#072)
"It is difficult to get the news from poems, yet men die miserably every day from lack of what is found there" WC Williams
Old 10-27-2006, 06:34 AM
  Pelican Parts Technical Article Directory    Reply With Quote #2 (permalink)
Living on borrowed time!
JonyRR's Avatar
'Just bought an InDuct(?) and power filter kit from San Jose BMW. Getting the plastic snorkel unit on has me scratching my head. Very tight against the battery. Looks like the battery has to be pushed forward a little. Don't want to break anything. The instructions don't address the tight fit. Any install tips/observations appreciated.'
Noticed that, didja
It's TOO tight. I just got done making a custom battery box/mount that moves the battery down and forward by appx. 2". That lets me craft a custom large duct with a much straighter shot into the filter. I'm using a SJ powerfilter assembly with the snorkel I made fitting onto the top of the SJfilter base..it looks almost exactly like a cylinderhead intake tract and I can shove my arm all the way down the duct to touch the filter. When it's totally complete I'llpost pix..I call it 'uberschnorkel'..this is the second iteration, this one made of 'glass instead of cobbled up out of sheetmetal and flexiduct.
Better a has-been than a wanna-be
'I am John Andrew Moffett of the Clan Moffat and by god I live, love, seek, fail, grieve and die as I so choose and I call no man master save me'.
Old 10-27-2006, 09:05 AM
  Pelican Parts Technical Article Directory    Reply With Quote #3 (permalink)
Doogie Howser's Avatar
WOW....your whole arm?! Good thing you've got a PCIII, otherwise that sucker would be running REALLY lean.
Let us know how it works out. I'm a fiberglass junkie, and would be interested in how you go about it.
Old 10-27-2006, 12:00 PM
  Pelican Parts Technical Article Directory    Reply With Quote #4 (permalink)
roger albert's Avatar
InDuct is a specific product name. (the one Lennie manufs and markets)
You have the plastic SJBMW piece, which is a pretty darn tight fit.
99 R11S w/ BBP, InDuct, Öhlins, PVMs, Braking, SJ-Filter, ZTech, HIDs
D675 R90Cafe R60/2 M900 SV650-SS CBR150R XR125 & CRF175 Motards
OnRoad OffRoad Cycles, Austin, TX: BMW, Ital, Suspension, Electrics
Dealer for K-Tech, JRI, GP Suspension, Penske, Öhlins, RaceTech, Elka, Wilbers, IKON & Works
www.ororcycle.com
CMRA EXPERT #841
Various Formula 5, 6 & 7 championships 2006-2012
A3, Navigator,
Old 10-27-2006, 12:35 PM
  Pelican Parts Technical Article Directory    Reply With Quote #5 (permalink)
JonyRR's Avatar
If I could find a rubber compound flexible enough to pull out of the inside of the schnorkel after it set up I could build a plug but I don't want to cut up the finished product to make the plug I need to make the mold...the mold would have to be multi-part, which I can handle.
I'm open to suggestions.
Old 10-27-2006, 12:39 PM
  Pelican Parts Technical Article Directory    Reply With Quote #6 (permalink)
Now Available for Ordering:   101 Projects For Your BMW 3 Series 1982-2000  [more info]
Roger is right, I misspoke. The InDuct is totally separate from San Jose BMW. Anyway, got it put in place after I figured out that the drilled holes on the plastic snorkel didn't match up precisely with the aluminum power filter holes. After I re-drilled them to match, it went into place, but very tight. I hope the $400+ was worth it (snorkel, power filter, snorkle tip). Also added some Wunderlich swing-arm covers, which should make the bike run at least 10mph faster. Plus, my new Cee Bailey's dark smoke windshield adds about 5hp.
Old 10-27-2006, 06:29 PM
  Pelican Parts Technical Article Directory    Reply With Quote #7 (permalink)
jdlowery's Avatar
SJBMW induct is also carbon fiber. This is true of the snorkel too.
Jim
'07, Lexus IS350; '03, Acura MDX; '01, R1100S; '80, R65; '76, Honda CB750 Four; '70, VW Beetle; '64, Triumph Bonneville; '55, R25/3
Old 10-28-2006, 12:30 AM
  Pelican Parts Technical Article Directory    Reply With Quote #8 (permalink)
lht lht is offline
Not only is the induct tight fitting around the tank, it pushes the left side body panals out of alignment. The snorkel in the front also pushes out the body panel. At full right hand lock of the front end, the snorkel hits the fender.
I noticed an increase in induct noise. Earplugs all the time now. The left panal vibrates enough to be noticable. It runs a little better. Someone said they were getting second gear power wheelies (bull****).
Just dont expect to much out of this setup. Don't associate noise with power.
LT
Old 10-28-2006, 07:01 AM
  Pelican Parts Technical Article Directory    Reply With Quote #9 (permalink)
Raven's Avatar
Why not?
Harley riders do
Lennie's induct slides right into place. A little chaffing here and there but nothing to speak about.
Don’t believe everything you think!
I don't suffer from insanity, I enjoy it!
2000 red R1100s, 1983 Gold Wing Aspencade, 2003 CRF450R, 1996 KLX 650, 2006 Ford F250 super crew long bed
Old 10-28-2006, 08:19 AM
  Pelican Parts Technical Article Directory    Reply With Quote #10 (permalink)
RoundelRider's Avatar
Send a message via Yahoo to RoundelRider
Originally posted by Raven
Why not?
Harley riders do
+1
My Lennies InDuct fits damn prefect. Yeah it rubbs on the body panel but dosent make it out of line, nor does it contact the fender or any other moving parts. It also fits perfectly with the SJ Powerfilter!
John
'03 R1100S Prep RIP
Old 10-28-2006, 03:32 PM
  Pelican Parts Technical Article Directory    Reply With Quote #11 (permalink)
No Info on (t)his member
jclark's Avatar
Gee, my Superduct® intake port and Superduct® seem to be made of fibreglass...
jeff
... could be early/late manufacturing...
Old 10-29-2006, 09:14 AM
  Pelican Parts Technical Article Directory    Reply With Quote #12 (permalink)
Jclark has it right. I remembered the SJ product was a cheaper material than CF, but incorrectly called it plastic instead of fiberglass.
www.ororcycle.com
CMRA EXPERT #841
A3, Navigator,
Old 10-29-2006, 09:21 AM
  Pelican Parts Technical Article Directory    Reply With Quote #13 (permalink)
unsafe at any speed
wswartzwel's Avatar
I put some adhesive backed foam, on my side panel to keep it from marking the carbon fiber on my induct, where it barely touches in one spot... other than that, perfect fit.
Bill Swartzwelder
2002 R1100S Prep/2006 BMW R1200GS
1969 BSA StarFire
Old 10-29-2006, 09:57 AM
  Pelican Parts Technical Article Directory    Reply With Quote #14 (permalink)
jdlowery's Avatar
True, I meant fiberglass but it came out carbon fiber. Definitely not plastic. Both of my pieces have been sold so I'm back to the original plastic.
Jim
Old 10-29-2006, 11:50 AM
  Pelican Parts Technical Article Directory    Reply With Quote #15 (permalink)
anotheroldrider's Avatar
Try Devcon Flexane products - it's a two-part urethane rubber available in a variety of durometer ratings in "brushable", "castable", and "trowelable" thicknesses. I've used it for molding small "bumpers" under fuel tanks, etc and for sealing the spoke nipples on my supermoto to run tubeless.
I'll ride anything with two wheels as long as I don't have to pedal it (except maybe to get it started)
Old 10-31-2006, 01:11 PM
  Pelican Parts Technical Article Directory    Reply With Quote #16 (permalink)
Barback King
Rapid Dog's Avatar
cool, i like new product info.
i used pieces of adhesive backed cell foam and rubber gasket material on just the hot spots where it rubs...this helps keep down those vibration noises
R11S CNC BARBACKS
'13 F800GT, '91 R100GS, '09 KTM 450EXC (Yeah, I had an S once)...
Old 10-31-2006, 01:31 PM
  Pelican Parts Technical Article Directory    Reply With Quote #17 (permalink)
JonyRR's Avatar
'Try Devcon Flexane products - it's a two-part urethane rubber available in a variety of durometer ratings in "brushable", "castable", and "trowelable"'
thanks for the info. this big schnorkel is almost ready for prime time. this weekend should see a good road test. I think my chichaucha could crawl completely thru it
Old 10-31-2006, 02:40 PM
  Pelican Parts Technical Article Directory    Reply With Quote #18 (permalink)
I had to have my wife pick mine up while shopping in Tulsa - I live in a small town in eastern OK. Their website has a searchable distributer list. It's not cheap - enough to do one pair of wheels on my KTM was about $100US with cleaner and prep. Good stuff, though - in three years as my favorite street toy neither wheel has ever lost air. GE also makes a castable rubber, but the only one I've ever seen was red.
Old 10-31-2006, 03:07 PM
  Pelican Parts Technical Article Directory    Reply With Quote #19 (permalink)
varmint's Avatar
i just bought the ducts from lowery.
am kind of pissed to realize they're not cf.
took about an hour to install. 90% of that was spent stripping off the plastics, and looking for allen wrenches. only had time for a once around the block before dark. it sounds nice, but havn't got a real feel for it yet.
99R1100S
97M2
01V92C
Old 10-31-2006, 06:15 PM
  Pelican Parts Technical Article Directory    Reply With Quote #20 (permalink)
Copyright 2017 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
