BCR Mounting Brackets for Belly Pan
I posted this on the F/S page but I need the info if available. Anyone have an extra set of belly pan mounting hardware? The red,white and blue? If not, plan "B" is to come up with something and I'd like some advice as to what I can use other than from the dealer. The issue sems to be mounting the front. The rear looks like it attatches to the centerstand holes.
Old 11-12-2006, 12:34 PM
Dbltailexit's Avatar
Let me know what you need, changing oil this week and can take pictures. ingmar
Lotus 7 replica, 4 wheeled motorcycle.
Old 11-13-2006, 06:01 PM
Thanks ingmar, I need pics of the attatchment points front and rear. I'm thinking I can use the rear centerstand bushings and just need screws but the front I believe has a bracket.
Old 11-13-2006, 06:14 PM
peterz's Avatar
John, here you go.
Front:
Rear:
Bolt details should be available from http://www.realoem.com/bmw.
I can send the hi-res images if you need, the forum limits to 800x600. PM me your email and and I'll forward the full size files.
-Peter
Old 11-14-2006, 05:59 AM
I cant see the images...
Can you send to me PM?
Do you know where can I bought this parts?
Old 10-04-2017, 02:07 AM
The dimensions for that front bracket can be found here if you want to try fabricating: R1100S Belly Pan Bracket
They look to be still available through the parts fiche at the typical BMW low price of $247.25 (Part Number is 46637708563). I guess the question now becomes how much do you value your time? Let us know how the fabrication goes.
Regards,
Kyler
Old 10-04-2017, 04:22 AM
"A" "A" is offline
el Cheapo
"A"'s Avatar
I have a set of mounting bracket/hardware still in package..
I was saving it in case I ever come across a bellypan for my R1100S.
Old 10-08-2017, 05:11 AM
Never a big fan of the belly pan so I have one sitting around from a 2004 BCR - very good shape with no cracks. The PO had coated the very underside with what looks like the protective coating used on truck beds - not visible when mounted on the bike. If anyone is interested, contact me. Also have the mounting hardware.
'04 R1100S BCR, '07 F800S (sold), '04 R1100S (totaled), '15 Thruxton (sold),'90 NT650 (sold), '86 SRX6 (sold - worse decision I ever made)
Old 10-14-2017, 03:14 AM
I would be interested in the belly ban you have with or without the mounting hardware, let me know what you want for it ? PM sent
Old 10-14-2017, 05:43 AM
Sorry for not sticking to the rules - this should be over in the FS section. There are two interested parties and I'll go by time of response. We can finish our discussion by PM - please check for my responses.
Old 10-14-2017, 06:15 AM
