The Importance of Pre-Ride Inspections
I ventured out into the garage to test out the heated vest I received for Christmas. While passing behind the bike, I brushed against the license plate frame and felt it move. Looking down I could see that the whole assembly had rotated out of kilter.
![]() Upon closer inspection, I found that 3 of the 4 bolts holding the unit to the exhaust cans were missing and that the fourth was loose. ![]() Yikes, I could only imagine the carnage that might have been brought forth had the last bolt been lost. The rear tire could have caught the assembly and sucked it forward, sharp edges slashing at the rubber...... Guess I will be performing more extensive pre-ride inspections from now on. Brock
I sure do feel a lot more like I do now than when I first got here...... 2016 S1000XR,2001 R1100 SA: Wunderlich Seat, Staintunes, Wilbers F/R 2004 MV Agusta Brutale S 1973 BMW 2002 Touring tii, '12 LR4, 86 Mondial 3.2 QV, 02 996 Turbo |
Man it's flat out here!
Thanks for that note Tirebiter...Glad you caught it soon enough.
I'll be looking at mine too...the Z-Tech Lic. Mount is a little different though with fewer fasteners.
"What I've tried to do in the two books I've done, Signature in the Cell and Darwin's Doubt, is to show just how weak the materialist's hand is in explaining the key events in the history of life. ... We would encourage people to roll up their sleeves, do their homework on this." Stephen Meyer PHD |
Living on borrowed time!
cross legs on the floor, burn some castrol R for incense and repeat after me:
'loctite, safety wire, locknuts' 'loctite, safety wire, locknuts' 'loctite, safety wire, locknuts' 'loctite, safety wire, locknuts' 'loctite, safety wire, locknuts' these things vibrate like a paint mixer on methamphetamine. Some have snickered at my safety-wired, jamnutted, locknutted R1100S. my reply is I haven't lost any parts since I first brought it home and I don't intend to start now.
Better a has-been than a wanna-be 'I am John Andrew Moffett of the Clan Moffat and by god I live, love, seek, fail, grieve and die as I so choose and I call no man master save me'. |
Why doea any good pilot preflight his plane?? Because a problem could be fatal.
Well our sport can be just as deadly if a mechanical failure should occur, I try to do a preflight every time I ride, and during the day if on a long trek. if I don't check the pressure, I always give both tires a kick with the heal, suprisingly accurate to find a soft tire.
Richard 2010 F800GS '04 R11BXA, '01 F650GS, '98 CBR600F3 track bike, '75 RE-5, '76 RE-5, '81 GS400E. Also residing in the barn my son's bikes: '89 GS500ES, Ducati Monster 620 dark |
President - Okie Chapter
I was always made to wash my own bikes by hand (making sure to touch Everything) starting at the ripe old age of 4, for this very reason.
Check it before, check it after for peace of mind.
___________________________ R1200s - Yellow, of course Two Wheel Oklahoma - Go watch it! |
old indian trick:
walk clockwise around bike every time you stop for fuel. gas up bike. take another lap, counter-clockwise around bike before you get back on. the concept is: find reasons NOT to ride". this method drives jeff williams nuts, which is part of the fun/reason for doing it.
'04 R1100s. I changed a couple o' things. |
I like that Brad . I'll have to start using that one on a regular basis.
dee jones |
Underwater basketweaver
I don't dismount her when I fill her tank.
Two days ago decided to take my bike to work after not riding for a about 3 weeks. You are right about the need of doing an inspection before riding. While I was riding in NYC I felt the bike handle strange. The bike felt very heavy and I was not able to turn and go around traffic. I then realized that my tires psi was very low. I got to say it was a strugle going to work and coming home with both tires low on air.
unsafe at any speed
I have seen video footage of this circle check you mentioned Brad. http://www.gromitspapa.com/EngineerRd.wmv Perhaps Jeff was doing a "Fleet check" of Carlton's, yours, and his own bike while stopped for traffic.. Behind a bus load of tourists... must have been right after riding some bumpy roads.
Bill Swartzwelder 2002 R1100S Prep/ 2024 Tenere 700 Last edited by wswartzwel; 12-29-2006 at 05:32 PM.. |
Man, that road looks like a blast!!!
ROFL, funy to see the kids waving, then all of a sudden spaceman comes running across the screen!
John '03 R1100S Prep RIP |
'99 Black SA "OBSSSN" - gone but not forgotten. Not all good technology is new, not all new technology is good. .........Purple is Satire......... |
I did note that BMW uses blue to secure the long bolts that hold the license plate/light assembly to the stock exhaust mounting plate (which is welded to the cans vs the Staintune bolt system)...regardless, it looks like the safest solution for this application would be to purchase longer bolts and then use jam nuts (and loctite?) or safety wire to secure the buggers.....
At work we use a "red" Loctite that HAS to be heated to like 350F before it lets go. Loctite is based on saccharides (sugar molecules). If you happen to get some under a fingernail or in a break in you skin and transfer it to your mouth (oops) it tastes sweet. And heat decomposes sugars.
ps: the Loctite advised for use on the transmission is a "solvent-tolerant" version. Loctite also makes some interesting compounds for retaining bearings and bushings.
Snob Pirate
Reminds me of that dealer in MN who sent me out on a test ride of a used K1 with 20 pounds of air in the tires. I thought it steered a little slow. My fault. I should have checked it out myself. I bought it anyway.
geo
"She sips nitro... with Phase 4 heads! 600 horsepower through the wheels! She's meanness set to music and the ***** is born to run!" Barry, MFP mechanic BMW/Yamaha/Suzuki I've been ionized, but I'm OK now. |
you need to get out and date more. or maybe just quit lighting bananas on fire. ......brad
Don't lick your tail assembly/muffler mount bolts! Mike |
Brad,
heck sparky I take off for NYC for a few days and you tell everyone about these habits I'm picking up from you to keep me from doing myself in........ .In few weeks we'll have some fun my friend. cya jeff
Riding, releases my mind from the tyranny of petty things. Thats why i ride. 2003 Boxer cup Rep 2113 Multistrada S Touring 95 R100RT Classic, a keeper |
Re: The Importance of Pre-Ride Inspections
Amen!! Yesterday, I was installing a Suburban Machinery peg lowering kit and looky what I found ...
2 of the 3 swingarm bolts were missing the the third was only finger tight!
2004 R1100S (2zars) 1957 Matchless G11 |
