pwillikers's Avatar
voltage output?
My radar detector is also a voltmeter. The S reads 14.7~15.3 volts and moves throughout the range actively. My cage runs 14.6 dead steady.
Is 15.3 V high?
Is the high variability a problem or indiciative of one?
Paul. '11 R1200RT, '09 Buell 1125cr, '08 Suzi SV650A, '00 Suzi SV650, '97 328i (with sticky ass tires - I love this car). And the bikes I used to own: '68 Bultaco 100, '69 Honda CL450, '71 Kawasaki Mach III, '71 OSSA Pioneer, '72 Honda MR175, '72 Benelli 250, '75 Yamaha RD350 (then college), '83 Honda VF750F (then kids),'96 MZ Skorpion, '99 R1100S, '01 SV650, '94 Honda VFR750F and '04 R1100S w/Öhlins an' stuff, most wrecked.
Old 01-12-2007, 11:50 AM
roger albert's Avatar
15.3 is getting up there.
Does it change with load? (high beam, grips etc)
Popped any bulbs?
Verified the 15.3 with a different meter in parallel?
i.e. is it really that high?
99 R11S w/ BBP, InDuct, Öhlins, PVMs, Braking, SJ-Filter, ZTech, HIDs
D675 R90Cafe R60/2 M900 SV650-SS CBR150R XR125 & CRF175 Motards
OnRoad OffRoad Cycles, Austin, TX: BMW, Ital, Suspension, Electrics
Dealer for K-Tech, JRI, GP Suspension, Penske, Öhlins, RaceTech, Elka, Wilbers, IKON & Works
www.ororcycle.com
CMRA EXPERT #841
Various Formula 5, 6 & 7 championships 2006-2012
A3, Navigator,
Old 01-12-2007, 01:31 PM
This is higher than I've seen. I was under the assumption that 14.5 or so volts was about the normal upper end of motorcycle electrical systems.
I'd first confirm the voltmeter's accuracy. 14.6 sounds high for the car too.
My FJR seems to like to cycle between 14.0 and 14.3 V (with nominal load - lower with load). It appears to be somewhat regular. Others have noted this and consider it inherent in the system. Never instrumented a BMW motorcycle though.
- Mark
Old 01-12-2007, 02:38 PM
pwillikers's Avatar
Back home from a week in glorious Houston. I double (triple) checked with two volt meters. When the radar detector reads 15.3V, both volt meters read 14.6V. I should have suspected this myself. Mystery solved. Thanks.
Old 01-14-2007, 11:01 AM
Living on borrowed time!
JonyRR's Avatar
14.5 is the upper design limit on a typical 12V charging system. 15 and above indicates a problem somewhere, which you discovered as the meter wasn't accurate. Hope it detects radar better than it displays charging voltage
Better a has-been than a wanna-be
'I am John Andrew Moffett of the Clan Moffat and by god I live, love, seek, fail, grieve and die as I so choose and I call no man master save me'.
Old 01-14-2007, 11:39 AM
acidburn's Avatar
what they all said.
Check with a known real meter and go from there.
See what thebattery sees also, 15 is too high.
Except for a few cases the murderCycle rate is relatively low on this board, keep up the good numbers.
Old 01-14-2007, 04:10 PM
At 15+ V, a wet battery would go dry fast I think. That would also kill gel batteries, that would be a symptom
tom rides and runs but 4 wheels no more;
added a '94 DR350SE goes to Mendocino, F650Dakar captain america sees Baja
R12S Red and Silver for cruising, the very first one was Honda C-90 way back when
Old 01-14-2007, 07:50 PM
