Windshield heights-
What is your windshield height, say center of bike, bottom to top? A BMW branded shield I had in the attic is 12 inches, and this will be mounted during my er correction of a November incident.
I believe the BCR's are all shorter than stock S's, and i had a tinted aftermarket shield before. My prior shield is gone and I have forgotten how much i cut it down to. I'm 6 ft. and thinking maybe cut down to 8 inches. what do you have? thanks ingmar
Lotus 7 replica, 4 wheeled motorcycle. |
12" is the BCR and prep, while 18" is the "touring model."
Orange '08 KTM 990 Adventure for fun in the rough stuff Patientlty awaiting an R-bike sport tourer devoid of servos and EWS |
Ride Far - Ride Fast
I cut my 12" stock one down 2 inches .... lots cleaner air ... might even give the 8" a shot
74 R90S, 77 R100RS, 85 K100RS, 2-87 K100RS 99 R11S 2002 Blue and White GS ... the prettiest ![]() 2008 KTM 950 Super Enduro long distance gravel road and general hooligan bike. Now an R11GS and a 650 Dakar |
No try, do or not do
please post pics of the cut down windshield, i am considering the same thing.
2017 R1200GSW Rallye Shreddr Signature Model |
Thanks Modog, that makes sense as it came with but off the bike. I will try it at 12 and start cutting from there.
Now to solve the won't turn over problem. As i just replaced throttle side controls which came from an earlier bike. Everything works except the starter? Thought this was covered earlier but search didn't find it.
The starter relay and motor are both behind this cover, so you can troubleshoot whether you're getting not getting 12V to the relay when you press the button, getting power to the relay but not the motor, or whether the motor is getting power but not turning. If you're not getting power to the relay, then the first thing I'd check is all the startup lockout circuits - sidestand, neutral switch, and clutch. I believe the algorithm is: if in neutral (N light on): bike starts/runs regardless of clutch or sidestand if not in neutral (N light off): >>if sidestand down: bike won't run/start >>if sidestand up: >>>>if clutch pulled: bike starts/runs >>>>if clutch not pulled: bike will run but won't start - Mark |
thanks Mark
good step by step that confirmed my days work.. Working off GS wiring diagram posted earlier (similar but not same), and then comparing remnants of original and replacement. early and new have 7 wires coming from controls but only 6 used to plug into socket. finally figured green/yellow joins green red in soldered joint inline. it worked. as an aside early harness front brake switch is opposite of later, one is always on, one is always off. sockets don't match up either, so shorten overlenght stock wiring (must be same for GS?) for both brake and switch controls and solder, shrink wrap all. oh watch out for centering spring on kill switch, tiny and hides well, and hidden screw under chrome decal. hope this helps someone in future. ingmar
