Today's Wrenching
Today I set about doing the annual service on the bike. I had previously picked up the fluid for the final drive and the trans. DOH! I realized already I forgot to get engine oil. I thought I had some around, guess not. So I took it out for a brief drive around the block just to warm it up. Then I set about changing the tranny fluid. DOH! The drain plug for the trans is a 14mm hex cap and the largest I have is 12mm. I guess I can’t do that today. So I decided to go ahead and do the final drive. I did have the annual service done last year at 1000 or so miles. The bike now has 4911. So I drained the final drive and the fluid was very clean. Now I am wondering if I should even bother with the transmission fluid. I guess I will go ahead and do it tomorrow once I get the proper hex cap bolt.
![]() I also decided to remove the rear tire and install the carbon hugger I got over the winter from MLS on eBay. ![]() The hugger mounts where the factor shock guard goes using the factory hardware. I decided to use two washers on the bolts when installing it. ![]() ![]() The mounting holes ![]() I am a little disappointed. I would have to say its more of a splash shield that a hugger. Over all its got a nice finish and I guess that’s what you get for $59 USD. I guess you get what you pay for. ![]() The left side installed ![]() Right side ![]() I also installed my Rick Mayer seat I had made back in November. I got the basket weave vinyl finish. I am pretty happy with how it game out. It looks great, it doesn’t pitch you forward like the old one, and in the 5 miles I rode it seems pretty comfortable. ![]() one more view of the seat ![]() I decided not to change the brake fluid today also because I am going to be installing stainless steel brake lines and I haven't received the rear one yet. So I will just wait and do it all at once.
Yes, BMW does make motorcycles..... 2000 R1100S Ztechnick exhust FosterRad Fuel Chip Ohlins F&R BMW MOA#125237 http://empeg9000.blogspot.com/ Last edited by stephen914; 03-24-2007 at 02:53 PM.. |
You could run just short of forever on the rear drive fluid, in a pinch. Not that I'm recommending that. The trans however, is another matter, and should absolutely be changed.
hth roger
99 R11S w/ BBP, InDuct, Öhlins, PVMs, Braking, SJ-Filter, ZTech, HIDs D675 R90Cafe R60/2 M900 SV650-SS CBR150R XR125 & CRF175 Motards OnRoad OffRoad Cycles, Austin, TX: BMW, Ital, Suspension, Electrics Dealer for K-Tech, JRI, GP Suspension, Penske, Öhlins, RaceTech, Elka, Wilbers, IKON & Works www.ororcycle.com CMRA EXPERT #841 Various Formula 5, 6 & 7 championships 2006-2012 A3, Navigator, |
Hey;
From the looks of the photo is the Hugger touching the pipe if so it will melt or rub a hole thru it. You may want to put some spacers between the hugger and the mounting point.
Dyno'd 104Hp 74.3 ft lbs torque at the rear wheel ![]() 1150 cylinders 12:1 pistons/ race cams, Lennies induct, Laser Boxercup II Exhaust, Ohlins shocks, Dymag Carbon Fiber Five Spoke wheels, Crossover tube removed, heads ported and polished Bigger valves installed intake and exhaust! SJ power filter, motoyoyo clamps , HID
Yes, BMW does make motorcycles..... 2000 R1100S Ztechnick exhust FosterRad Fuel Chip Ohlins F&R BMW MOA#125237 http://empeg9000.blogspot.com/ |
Uh....who me?
Maybe put an angled spacer in it so that the hugger actually hugs the rear tire a bit more. Just a thought.
PS....wrenching threads with pics are what this forum is all about. Thanks for letting us watch.
Bob Hancock '20 KTM1290 SuperAdventure S, 2006 KTM 660RFR Dakar, 1966 Honda 305 Scrambler, 2019 Camaro 2SS 1LE, 2020 Chevy Trail Boss "There are times when good words are to be left unsaid out of esteem for silence." St. Benedict |
Man it's flat out here!
Nice write-up on the lower cost Hugger and RM Seat...yes, thanks for sharing.
I got a 14mm Hex-Head Wrench at the local Hardware Store and had it cut down a bit shorter so it would fit in the small confines above the Exhaust Header.
"What I've tried to do in the two books I've done, Signature in the Cell and Darwin's Doubt, is to show just how weak the materialist's hand is in explaining the key events in the history of life. ... We would encourage people to roll up their sleeves, do their homework on this." Stephen Meyer PHD |
