Go Back   Pelican Parts Forums > 2- BMW Forums > BMW Technical Forums > BMW R1100S / R1200S Tech Forum
acidburn's Avatar
Leaded vs Unleaded fuels???
Can i run leaded in a noncat converter bike that is fuel injected?
My understanding was yes, no effect on the injectors, i am getting conflicting stories?
Not necessarily BMW but yes BMW's too.
Acid
Except for a few cases the murderCycle rate is relatively low on this board, keep up the good numbers.
Old 04-17-2007, 03:08 PM
No Info on (t)his member
jclark's Avatar
Yes you may.
jeff
_________________________
jeff clark
99 R1100S
82 Alfa Romeo Spider Veloce
Old 04-17-2007, 03:09 PM
acidburn's Avatar
Should i though? will it gum up the injectors?, thats what some are saying, no reply from Vp yet, i really thought it was o.k.
The sv650 railed on c-12 leaded this weekend, it was unreal.
Old 04-17-2007, 03:23 PM
Snob Pirate
geothepencil's Avatar
Ask the environmentalists or those who have a passing interest in the effects on people of the use of lead. I'll bet they would say no. Where do you get it these days ? From the good old boys of NASCAR or have they changed over in the past couple years ?
geo
"She sips nitro... with Phase 4 heads! 600 horsepower through the wheels! She's meanness set to music and the ***** is born to run!" Barry, MFP mechanic
BMW/Yamaha/Suzuki
I've been ionized, but I'm OK now.
Old 04-17-2007, 03:41 PM
I wouldn't think it would hurt anything, although over time it does lead to more combustion chamber deposits, spark plug deposits, etc. But that's in the combustion environment - I don't think the injectors will care a bit - I've never heard of lead deposits upstream of the combustion chamber.
But I wouldn't run leaded fuel unless you had a good reason to. Some folks think the 100LL aviation fuel (which despite the "low lead" name has 4x the lead that used to be in leaded regular) is going to make their bikes magically run better when, by itself, it probably makes their bikes run worse. And you have to do research on how octane numbers are determined - octane numbers are measured differently for various types of gasolines.
- Mark
Old 04-17-2007, 04:24 PM
acidburn's Avatar
From Vp racing fuels.
I am not aware of any problems with 03 injected models using our C12.
Jay Farnsworth
Technical Director
VP Racing Fuels, Inc.
I am happpeeeee. the Sv runs real fine on this stuff.
Get it at th track or your dealer.
6.50/g at the track for c-12.
Old 04-17-2007, 04:39 PM
so acid, are you trying to stay ahead of the curve by conditioning yourself to buying six buck a gallon fuel?
in socal, regular pump gas is currently over $3.50. i've parked my van and now only use the '79 v-dub or the bike.
...and both get stuffed and splooged by the cheapest-priced nozzle available.
'04 R1100s. I changed a couple o' things.
Old 04-17-2007, 04:43 PM
acidburn's Avatar
nope, just trying to optimize at the track, which has been every other week for a good few now.
Old 04-17-2007, 07:44 PM
acidburn's Avatar
that didnt work
Old 04-17-2007, 07:53 PM
roger albert's Avatar
If you're not running such high compression that you're detonating, then C12 isn't buying you much, except theoretically, consistency. And they way they've been blending U-series lately, I skeptical of even that.
99 R11S w/ BBP, InDuct, Íhlins, PVMs, Braking, SJ-Filter, ZTech, HIDs
D675 R90Cafe R60/2 M900 SV650-SS CBR150R XR125 & CRF175 Motards
OnRoad OffRoad Cycles, Austin, TX: BMW, Ital, Suspension, Electrics
Dealer for K-Tech, JRI, GP Suspension, Penske, Íhlins, RaceTech, Elka, Wilbers, IKON & Works
www.ororcycle.com
CMRA EXPERT #841
Various Formula 5, 6 & 7 championships 2006-2012
A3, Navigator,
Old 04-17-2007, 09:32 PM
acidburn's Avatar
It ran better than i thought i was capable of at 10500 which is where i tap the power shifter, smooth, consistant, seemless shifts, really a huge improvement, better throttle reponse over all.
Well worth it for me.
Old 04-18-2007, 06:24 AM
Living on borrowed time!
JonyRR's Avatar
acid;
and that's the kind of result you should see with VP, camII or similar.
it's blended specifically for consistent combustion, max power, even vapor release..considerations not always at the top of the list for pump gas.
avgas is NOT designed for this purpose; it's designed for steady-state operation at higher elevation levels.
now it's time to try one of 'those' additives.
jetting and timing are key here.
Better a has-been than a wanna-be
'I am John Andrew Moffett of the Clan Moffat and by god I live, love, seek, fail, grieve and die as I so choose and I call no man master save me'.
Old 04-18-2007, 11:26 AM
acidburn's Avatar
I dont know who is talking about Av gas or other fuels, not me,,,, at this time the C-12 is running so well ill go with that for the next two times out in may.
The Pc3 with the enhancement program running (accel pump program) is doing an excellent job for me.
The TRE plug in from Ivan is handling the rest and doing a good job of it vs when i was stock timing retard pkg in 1-4 gears up to 1/2 throttle, now i have it all form zero throttle in all gears.
Jetting?
The fule adders you refer to are of extemely high interest.
We need to talk some time at length eudmacate me Mr. Wizard before i spec the new motor.
This is too fun and im only running a piss ant 650.
Of course the 1k bike is almost ready to role, close very close.
Old 04-18-2007, 12:25 PM
JonyRR's Avatar
remember the original oxygenated 'elf' fuel?
that stuff was downright nasty. breathing it made me immediately violently ill, +6% oxygen, according to jon cornwell.
made typically +5 HP in any application.
at $25.00@gallon, most considerd it money welll spent.
Old 04-18-2007, 01:37 PM
JonyRR's Avatar
if you really want to find out about fuels, hang out with the drag race crowd at some level above the weekenders.
if you know someone on an AA/altered team, pump the fuels guy (or girl) for knowledge. they've had the fuels thing down cold for a long time.
xylene, toluene, propelyene oxide, and yes ACETONE (frack you naysayers, when you actually DO something instread of kibitz endlessly maybe I'll be impressed) all have some utility here.
then there's the genuine nitro derivitaves like nitroparrifin. mucho HP increase and you can get a long engine life if you do it right.
Old 04-18-2007, 01:47 PM
acidburn's Avatar
i dont have time for the Drags right now, i do have quality contacts over there but they drag me in to the scene, there will be a time when i move to Or, PIR wont be the same once it Acidic.
I still ahve a few cases of Nitro and catalyst here, will it melt my Kevlar tank?
Old 04-18-2007, 02:38 PM
JonyRR's Avatar
'will it melt my Kevlar tank?'
I seriously doubt it, but ask that tank guy you got it from.
way back, I'v eseen some issues with polyester-based fiberglass tanks, but that was is the dark ages and with a fuel brew that was seriously nasty, inlcuding having genuine hydrazine and propelyene oxide in the mix.
I've put many a lap around PIR. make it up this way and we'll go trail riding in the cascades..I'm breaking in a new generation of fresh meat (new cubie and new trail rider) right now. let the punishment begin...
Old 04-18-2007, 03:12 PM
