Last fall I had a rubber front brake line fail on my ’01 11S with ABS, so I replaced all the lines with Spiegler SS lines. I also replaced the front pads, likely the original pads, with EBC HH pads. The pads make some disturbing sounds when they are cold, under light braking. There also seems to be a bit of a shudder when this is occurring. It’s the worst when I leave work and am pretty much coasting down the parking ramp, it sounds like someone is dragging a metal chair across a concrete floor. It tends to go away once the brakes warm up. It stops fine, the pads squeal too, but I can live with that.
I’ve removed the pads, cleaned and sanded them lightly, I’ve also cleaned and sanded the rotors a few times to no avail. They don’t squawk or shudder in rain by the way. Is this common with EBC pads or is something else going on? It didn’t do this before the brake line and pad replacement. Thanks
Doug Minneapolis, MN '01 R1100S ABS, Öhlins, Ztechnik exhaust, Corbin "Ol' Yeller" '03 Yamaha TW200 "Skippy" |
R1100S
You could try some brake cleaner. Ive never tried it myself but if you happy that the brakes are working perfectly it might be worth a try.
Brake Cleaner - Supercheap Auto Australia Thanx Dave |
I've gone through a couple cans of brake cleaner to no effect.
2001 R1100SA
I replaced the front pads on my '01 ABS with EBC HH pads, and have had no issues. I did use an anti-squeel paste when I installed the pads, and bedded them after the install. I also replaced the pins, as mine had some corrosion on them.
Ciocc Last edited by Ciocc; 04-23-2012 at 12:32 PM.. |
R1100S
Ive heard of people using a small amount of silicon on the back of the pad to stop them shuddering. Just a small dab where the piston touches the pad.
Thanx Dave |
Gasteropod Rider
When I was shopping for pads, I've read similar stories on EBC. Very second hand witnessing here.
Track addict
My friend bought ebc pads for his honda 600 and they are doing something similar, you can hear a grinding sound at low speeds and see the effect on the rotors too. I think the pads are just really hard.
R1200S Black, Ohlins, 6" Rear wheel, Akrapovic Slip on |
Misfit
You'd be wise to ball hone or emery-cloth sand those rotors when switching pad types.
N.
Nils Menten - Tucson, Arizona, USA* 2001 R1100S "Light", gone but not forgotten. http://tinyurl.com/zv3tpc5 I Do Vapor Blasting! Visit restocycle.com for information. Ikon shocks for your BMW! https://www.ikonshocksusa.com/ |
Underwater basketweaver
Yes, emery cloth or Garnet sandpaper... don't use 'common' sandpaper either. Regular sanding paper (aluminium oxide) can cause more harm than good.
'05 R12GS '08 HP2 Sport '16 GT4 |
I see you
I've used EBC HH for years and they have always clattered. They also always stop the bike just fine.
Si non potes inimicum tuum vincere, habeas eum amicum and ride a big blue trike. "'Bipartisan' usually means that a larger-than-usual deception is being carried out." |
Man it's flat out here!
I had similar problems on my '99 with EBC HH Pads until I switch out to the correct EBC P/N: FA407HH
Here's my log entries: 25AUG2008 - @53,135 Miles I’ve finally discovered what’s rattling up front. It’s the Front Brake Pads…I can rattle them with my fingers through the top opening of the Calipers. The EBC Brake Pads (P/N: FA246HH) do not have an “anti-rattle” clip on them. They’ve been superseded by EBC P/N: FA407HH which have the “anti-rattle” clip. I installed the EBC Front Brake Pads 13,758 Miles ago. I checked the Pad material depth on the front and rear calipers…plenty left to go. The front OEM Pads lasted almost 40K Miles. I’ll install the newer ones next time. 12AUG2009 – I replaced the Front EBC FA246HH Brake Pads (19,607 Miles total use) with new EBC FA407HH Brake Pads. The FA407HH pad has a small metal spring clip that keeps the pad from rattling against the Calipers unlike the FA246HH pad which doesn’t have a spring clip. This will finally eliminate the rattling sound emanating from the front brake calipers. ![]() Also the older R1100S had smaller diameter front discs so not 100% sure if this is the correct P/N for your 2001 model.
"What I've tried to do in the two books I've done, Signature in the Cell and Darwin's Doubt, is to show just how weak the materialist's hand is in explaining the key events in the history of life. ... We would encourage people to roll up their sleeves, do their homework on this." Stephen Meyer PHD Last edited by R111S; 04-23-2012 at 03:52 PM.. |
Well I found some time to pull the pads. They have the anti-rattle springs. I hit the rotors with some emery cloth. Cleaned the pads and rotors again. I put a thin layer of Disk Brake Quiet on the pads and let that dry.
On a brief ride the squawking and squealing were gone. I haven't been in the office lately, so the parking ramp test awaits. Hopefully this is the cure. Thanks everybody!
