www.hyperprousa.com
Model # SDK-BM-111BA, RSC version, $340 If you go with this one, talk to Throttlemeister. The instructions are for an R1100R and you have to mount the damper body different so it doesn't hit the lower part of your fairing. |
Do not take too seriously
Bikerfish: I went with SDK-BM-111GA. To me, the reason for picking the RSC version is that I do not want to know a steering damper is present, until it is actually preventing a slapper. The RSC curve allows just that: very little to no resistance at normal speeds, combined with an extremely rapidly increasing resistance when a slapper occurs. In the real world it means I can yank the bars without noticing the damper, while it can still catch a slapper dead in its tracks.
A linear damper like the CSC is more of a trade-off between resistance at normal operation and effectiveness during a slapper. Which one you prefer is your preference.
BMW R1100S 'Bumble Bee' | HyperPro 3D F&R | motoyoyo clamps | Staintune | some other bits BMW K1200S 'tri-color ICBM' | WP ESA rebuild to specifications | lots of other bits http://www.sport-touring.eu | http://eurotravel.photos |
so jduke says BA, throttlemeister claims GA. what's the diff?
"Wow I'm an idiot, thanks bikerfish!" Harleys are like opinions, every a-hole's got one! 2001 R11S "lite", with a few mods. 2009 F800GS. has a better saddle. and other stuff. (sold) 2016 R12GSW 3Black. wow. |
jduke has black anodized, I have gunmetal grey anodized. Otherwise, same part.
Huh?
The OEM BMW damper is sorta progressive, at least until it goes TU. Having had linear dampers on various Japanese sport bikes I'd be inclined to vote for the RSC. That damping necessary to stop a tankslapper may be more than feels comfortable when moving at slow speed. Or at least that was my experience. I was always futzing with the adjustment. I'm guessing that the RSC will be like the factory part, only better?
Lars Pedersen 2002 R1100S Prep, still soldiering on. Need to ride it more. 1970 Ford Bronco, far from stock; 2005 Subaru Outback wagon, departed, don't miss it. Replaced by The Storm Trooper, AKA a bone white 2019 Jeep Grand Cherokee Upland. Vans RV-7 flying as of June 24, 2012; Too many bicycles to list. |
I'm inclined to think anything is better than the factory part..
No Info on (t)his member
Well, my "factory part" has been working fine since ~2000, but when it gives up, I'll replace w/an Ohlins unit, just to be, uhh, 'matchy'...
jeff
_________________________ jeff clark 99 R1100S 82 Alfa Romeo Spider Veloce |
Steering Dampener
There isn't a "plug and play" Ohlins unit to my knowledge ...
Has there been a new deveopment?
------------------------------------------------ fiery '02 BMW X5 4.4i (Now gone ... sob!) '02 BMW R1100S BCR ABS '98 Range Rover (the Brontosaurus) |
The Ohlins can be mounted directly on the stock mounts, like the HyperPro. Make sure you get one with a 75mm stroke minimum.
Interesting ... In your case, was it a cost issue not to go with an Ohlins unit, or were there other factors?
I have very good experiences with HyperPro. And as far as I know, the Ohlins dampers are linear and I wanted progressive for reasons stated above. I realize it is not (yet) a big name in the US, but it is here back home. They build very high quality stuff. Stuff that works. They have a very different philosophy compared to the regular shock manufacturers. One that is focused on street use, instead of track use like all the others. But it is also one that really does work on the street. It takes time to convince people as most are stuck thinking in applying track tech to street, but I am sure it will work out as most that take the plunge are usually convinced once they feel the result.
BMW R1100S 'Bumble Bee' | HyperPro 3D F&R | motoyoyo clamps | Staintune | some other bits BMW K1200S 'tri-color ICBM' | WP ESA rebuild to specifications | lots of other bits http://www.sport-touring.eu | http://eurotravel.photos Last edited by throttlemeister; 06-04-2007 at 12:34 AM.. |
Looking at the Hyperpro USA site they list both versions at $340 which seems odd if the Active is their top of the line. Is the pricing the same for both in Europe? Has anyone attempted to rebuild the stock damper?
John B. 03 R1100S Prep(wife's), 02 Futura, 92 907ie, 89 Transalp, 87 R80/100, 82 Morini 3.5 sport, 76 R90/S, 73 R75/5 90 535im & 95 525i Touring 65, 66 Alfa Romeos |
No, in Europe the Active is about 50 euro more expensive.
I'm most of the way thru the install, and have a question. I have a fair amount of movement available to the damper at the frame mount, due to the joint arrangement that the bracket bolt passes thru. Is this correct? It seems to me that it should be more "clamped down" at that junction. On the stock unit, the damper mated to that bracket with a flat surface on the damper making contact- I believe that reduced the movement.
ah- got it. had to add a third soft washer for fairing distance, and remove the OEM metal washer on them. that was preventing things from getting snugged up. still some play in the eye joint, but it's no longer loose feeling.
"Wow I'm an idiot, thanks bikerfish!" Harleys are like opinions, every a-hole's got one! 2001 R11S "lite", with a few mods. 2009 F800GS. has a better saddle. and other stuff. (sold) 2016 R12GSW 3Black. wow. Last edited by bikerfish1100; 07-03-2007 at 08:33 PM.. |
No try, do or not do
for those that have Wilbers and like matching components, here is their version. It looks almost exactly like the Hyperpro, and is listed at $249 US on their website. When mine goes south, I will get this one.
http://www.motorcycle-suspension.com/steering_damper/wilbers/steering_damper/index.html ![]()
2017 R1200GSW Rallye Shreddr Signature Model |
Thread Tools | |
Rate This Thread | |
