Jeff Williams's Avatar
Help! Replace heated grips for airhead
Hi all,
I'm almost done restoring my 95 R100RT and need to change the grips. I've looked at the way heated grips are changed for the R1100 and 1200 but the airhead doesn't have weights at the end. could someone please point me to grips that would work for the old style heated grips.
jeff
Riding, releases my mind from the tyranny of petty things. Thats why i ride.
2003 Boxer cup Rep
2113 Multistrada S Touring
95 R100RT Classic, a keeper
Old 05-30-2007, 07:31 PM
I got some snowmobile heaters, they go under the grip. Got them with intent of putting them on the K bike, but never did.. Can try to dig up the info if needed, came out of the big catalog at a normal bike shop...
Does BMW not sell the Airhead heated grips anymore?
RIP Jeff Williams; RIP Brad Zimmerman
1989 K100RS - White/Blue, Remus; 1999 R1100S - Mandarin Orange, Remus, Ohlins; 2007 G650XCountry - Black/Silver, iStorm Luggage - Wilbers 75mm Lowered shock for the wife!; 2003 BCR #57 - Jeff's bike ; 2009 G477X - Akrapovic, WP Trax, SpeedBrain Goodies
2000 ///M5 - Custom Black & Blue, Dinan goodies
Old 05-30-2007, 09:29 PM
Barback King
Rapid Dog's Avatar
Jeff, on the GS I opted for snowmobile heaters (I think they're called too, work well and cheap (like $40), though you have to drill a hole at the center of your bars and feed the wiring through. I used an airhead heated grip rocker switch also.
Doesn't the bike have the OEM grips?
Here's the grips I used: Poly Grips ...you can getthem from Gary at RPM Cycles in Ventura...tell'em Rapid sent'cha......
R11S CNC BARBACKS
Now an R1200GSW rider...
Old 05-31-2007, 02:55 PM
R-dog,
so you got the rubber part of the grips from RPM in Ventura?
2003 Boxer cup Rep
Old 05-31-2007, 04:57 PM
Barback King
Rapid Dog's Avatar
no, I used some aftermarket rubber. the poly grips aren't grips at all...go figure...they are just the inserts, wiring,fuse, and switch.
They go inside the handlebar. That way you get touse the grips of your choice. For the GS I like used aftermarket Pro Grips
R11S CNC BARBACKS
Old 06-01-2007, 07:27 AM
Thanks R-dog
2003 Boxer cup Rep
Old 06-01-2007, 08:03 AM
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
