kick stand r1100s
What is the best way to get the side stand (kick stand) off? I'm trying to put my new flex-glass belly pan on an it's in the way.
Christopher Clary 04 R1100S track bike 00 R1100RT street Twins Motorsports LLC |
#50 torx bit, you may need some heat if it's been Locktited. I asume you have some way to keep the thing propped up (unless you're really fast).
Jim
down to jap bikes that run, a Ural, and a dead Norton |
pan
If its the BXC replica pan, roll the bike up on a 2"x6"x8'. Or a couple of two foot pieces under each tire. You need ground clearance. Two people are needed. I keep a piece of 2"x4" to rest the stand on.
Extend the sidestand and lean the bike to the right a little. Then thread the pan through the kickstand. I put a blanket on the floor first, to keep the pan from getting scratched. Method two is : Lean the bike way over on the right side and thread the stand through. There is really no easy way . It is a pain in the ass.
LT |
Re: pan
Barback King
...you will definirely need some heat, and a heat gun probably won't do it, a torch is better.
R11S CNC BARBACKS Now an R1200GSW rider... |
Thanks all for the help. I decided to take it to the shop and let Bill and the gang do it correctly.
Thread Tools | |
Rate This Thread | |
