R1200s Ohlins Setup
Looking for some guidance to set up the Ohlins on a new R1200s for a 215 pound rider. It appears that the canister may interfere with the front preload adjustment. If the canister can be removed or relocated, are there instructions available?
michaelfrane@verizon.net |
this is working for me at a riding weight of 195.
Static sag should be: Rear: 10-20mm Front: 15-30mm Total sag: Rear: 30-40mm Front: 28-38mm Damping Settings: Front : Öhlins front shock comes standard with a spring length of 184 mm (7.24 inch): set to 180 mm (7.09 inch). Set rebound: turn the wheel at the bottom all to the right, then 16 clicks back. Note: when you turn a clicker all the way in...and bury that sucker so it won't turn anymore...the first turn back out...the VERY FIRST click you feel is "zero". the next click is "one." Rear : Öhlins rear shock comes standard with a spring length of 158 mm (6.22 inch): set to 155 mm (6.10 inch). Set rebound: turn the little wheel at the bottom all to the right, then 32 clicks back. As for the canister.....ditch it; it will make room for the remote reservoir shock you'll put in there later. |
XORJO, thanks for the precise details on the shock setup. We'll try this as a base setting and let you know how it works.
no sweat...you probably already know that the stock spring on those shocks will be near the upper limit at a rider weight of 215. when the shocks go, you should have a different spring rate installed.
Fairly good advice. I'd not let the rear sag below 35mmm total though. 40mm rear sag will see her steering slowly and pushing the front end.
Similarly, a front sag anywhere near as low as 28mm will cause the same. 34-40 is a much better and safer target.
99 R11S w/ BBP, InDuct, Öhlins, PVMs, Braking, SJ-Filter, ZTech, HIDs D675 R90Cafe R60/2 M900 SV650-SS CBR150R XR125 & CRF175 Motards OnRoad OffRoad Cycles, Austin, TX: BMW, Ital, Suspension, Electrics Dealer for K-Tech, JRI, GP Suspension, Penske, Öhlins, RaceTech, Elka, Wilbers, IKON & Works www.ororcycle.com CMRA EXPERT #841 Various Formula 5, 6 & 7 championships 2006-2012 A3, Navigator, |
agreed....the sag settings are taken from Ohlins. me? i've got an Evo torque arm with all the shims in and sag set pretty tight. at 195 i think i'm at the limit of the springs. when they wear out, i'm ditching the emulsion front shock and hopefully, will be back down to 185 dressed. yea, yea......
Öhlins rear shock comes standard with a spring length of 158 mm (6.22 inch): set to 155 mm (6.10 inch). Set rebound: turn the little wheel at the bottom all to the right, then 32 clicks back.>> 32 clicks OUT for rebound?!? I can NOT imagine that, considering that the factory setting is 16 clicks. Anyone?
Mal Glanz Ft. Lauderdale, FL '12 ZX-14R '09 CBR1000RR (w/pegs & bars, now my touring bike) '10 S1000RR & '07 R1200S (gone, but loved 'em) |
yikes.
didn't even notice the damping settings (only paid attention to the sag) 32 out on the rear is indeed a lot. Factory setting isn't bad. If anything, I've had to go in a click or two to keep the rear from popping up too quickly.
what can i say, at 195lbs, this setting works for me
Just don't make a mistake between what feels good to you, and what works. Barring a really strange combination of tolerance stack, that rebound setting is almost assuredly a poor one compromising both traction and weight transfer. If you're riding way below the bike's limit, it will cause you no problem. But if the pace gets significant, it could bite you pretty good. Be careful!
(says the guy who had a pretty quick get off followed by a slide and then some aerial work in the last week) ( ( also caused partially by a poor rebound and preload choice ) ) grrrrrrr
You need to PM Bob Hancock. He just got a tutorial from the Ohlins rep at the Biltmore and I think he's already removed the cannister. He should be back on the PP site tomorrow or the next.
rog,
nothing personal, but what's your riding weight? this setting works for non-track canyon rides for me. even the bumpiest of on & off camber tight corners with posted limits of 20 can be taken at 60 with no worries. perhaps it is the minimal sag combined with the max shims on the torque arm.... |
No Problem
I'm about 150lb, maybe 20 more with all gear. But that is not the issue here. There are geometries that work well, and others less well. Once you've adjusted for sag, rider weight is largely out of the occasion. Rider weight affects how much adjustment is needed to GET to the correct sag, but not the correct sag itself. Note also that this isn't based on just me or my preferences, but in setting up a LOT of bikes. Probably a bit over 200 in the last year. More importantly, regardless of rider weight, you need at least a certain amount of rebound damping. W/o that, the rear feels plush, but isn't well controlled, and you can't read rear traction. On every Öhlins I've seen, 32 out would be not only off, but ridiculously so. There's a fair amount of variance in how the shock is assembled and just how many clicks you'll need, but the number you're reporting, based on doing hundreds and hundreds of dampers, seems pretty far off. I'm curious about Bob's (and others') numbers as well.
Uh....who me?
First a story and then
the numbers. BMW Atlanta set up the sag on the rear of my bike at delivery, but gave up messing with the front because of the cannister. At the 600 mile service, the cannister was removed and the tech set the sag at 35mm for both ends. I could probably use a little less sag up front, but it's really OK. I had been running rebound and compression damping settings per the book, but thought the front needed more rebound damping. The owners manual says, to increase damping, turn the knob counter-clockwise. So, I got down under there and turned it out....counterclockwise. It got worse....and worse and worse until it was backed all the way out and I was thinking I had a bad shock. (I'm a little slow I know so just you hush.
Bob Hancock '20 KTM1090 SuperAdventure S, '17 KTM 690er, '19 BMW F850GS, 2006 KTM 660R Dakar, 2001 Porsche Boxster S "There are times when good words are to be left unsaid out of esteem for silence." St. Benedict |
I just had my sag set at 30mm front and 40mm rear by my BMW dealer. That's what they recommended. But from what some of you are saying is 40 too much?
Bob - Just to confirm mine is right, since I always adjust looking TO the end I'm adjusting, clockwise (turning in) = firmer. Agreed?
Uh....who me?
Mal, agreed. When I get down in a squat, just behind the front wheel, being careful not to touch the header, turning the adjustment knob to the right will increase damping. Just like a standard right handed screw tightens things.
Barback King
Which will makes the shock return SLOWER on it's rebound stroke, correct? More damping = slower rebound speed Less damping = faster rebound speed AND More damping = slower compression speed Less damping = faster compression speed Tell me if I'm really really dyslexical here...
R11S CNC BARBACKS Now an R1200GSW rider... |
Uh....who me?
That's the way I understand it Rapid. I can tell you that with the front rebound adjuster backed all the way out to 46 it was like riding a pogo stick.....Bob Bouncin' down the road. Not a pretty sight.
When the Ohlins guy was playin' with it, he'd push down on the peg and the tank top at the same time...looking for them to compress and rebound at the same rate. With too little rebound damping, the bike would push down, and bounce back past the point of rest....sometimes oscillating like that twice with decreasing amplitude until it came to a rest. Fun to watch an expert ply his art.
Bob Hancock '20 KTM1090 SuperAdventure S, '17 KTM 690er, '19 BMW F850GS, 2006 KTM 660R Dakar, 2001 Porsche Boxster S "There are times when good words are to be left unsaid out of esteem for silence." St. Benedict Last edited by Bob Hancock; 06-18-2007 at 02:58 PM.. |
Thread Tools | |
Rate This Thread | |
