Spline: Good news, bad news.
My 99 started having hard shifts from 2nd to 1st after my last long trip, 30,000 miles on the odo, and I suspected the worst. They tore into it today and I went to check out the damage this afternoon. The tranny had been replaced under warranty by the P.O. at 6,000 miles. Splines were good but rusted, friction plate was barely worn, they suspect it was also replaced, slave cylinder was leaking. The shop that did the tranny work (Salem Ducati, BMW, Honda) used some type of red lube, I suspect the Honda Moly brand that has been discussed here, and it had turned to goop (what hadn't been slung off). My pivot bearings went out a year ago and when it was torn down the bearings were stuck in the housing bad, they also were lubed with a red grease that had broken down. The good news I guess is that I caught it early enough or was lucky enough to have no spline damage. Be careful what you use for lube is the moral of the story. The mighty S should be back together by the weekend, then its off to Utah, Colorado, Wyo, and Montana in 2 weeks!
99 Black r11s 02 klr 650 03 zrx 1200 08 thruxton 900 82 ascot 500 |
Re: Spline: Good news, bad news.
2010 HP2 Sport (sold) 2004 BCR #36 (sold) |
At one time the official BMW spline lube was red but they seem to change that recommendation every few years so its hard to keep track. From what I've seen none of these lubes seem to hold up long term on the tranny splines. I just did a spline lube on an Airhead that was previously done by a BMW dealer 30k ago. The splines were dry with light rust showing with no damage.
John B. 03 R1100S Prep(wife's), 02 Futura, 92 907ie, 89 Transalp, 87 R80/100, 82 Morini 3.5 sport, 76 R90/S, 73 R75/5 90 535im & 95 525i Touring 65, 66 Alfa Romeos |
Banned
Interesting post, thanks.
The traditional BMW goop is/was red. So, 24,000 miles ago, your tranny was replaced. Some folks think the assembly line may have screwed-up the greasing now and then or consistenty for a brief period or who knows. But I think we can take for granted that the dealer greased the splines correctly. If true, then your bike was rusting, if not quite dry and wearing, at 24,000. Seems early. Does your bike get any more grease-harming treatment than anybody else. Say, salt air or rain or leaky seals or something? |
The tech showed me the BMW lube that is going back on, about the color of Vasaline and very thick. I assumed the honda lube was red, tech said he thought it might have been some sort of marine lube. Seals were good and the bike is stored in a garage. I'm far enough from the coast that marine air isn't an issue although I've seen what it does to some bikes.
Thread Tools | |
Rate This Thread | |
