Question regarding high-mounted clip-ons
When I bought my '04 R1100S it came stock with the high (above the triple) mounted clip-ons. I am looking to get a set of low mounted ones but I would like to know if this is a simple switch, or if the forks differ in some way before I buy them.
Does anyone know from experience?
Thanks in advance.
Brent McGrath
Halifax, Nova Scotia, Canada
2004 BMW R1100S - Blue with custom decal
work.
Old 06-08-2007, 06:48 PM
motoyoyo's Avatar
Brent, there is no difference in the suspension on either setup. You should be able to mount your existing bars underneath the clamp. Your handlebars probably do not have the low bar alignment tab extension, but it really doesn't matter. The bars will stay in position perfectly fine as long as all the pinch bolts are tight. If you make some type of alignment mark with a felt pen that shows the existing position of the bars relative to the top clamp (rotationally), you can use this mark to get the same bar position when you swap them underneath.
The cables are most likely a little bit longer than the standard low bar version but should not be a problem either. After you swap the bars to the low position and get everything aligned and tightened, check that all the cables and hoses have adequate clearance when moving the bars from side to side.
Scott
'98 R1100S - Triple Clamps, 10mm Shortened Telelever
2007 Ducati S2R1000, 2008 KTM 990SDR
Old 06-08-2007, 06:59 PM
Cyclone Jack
hawkeyejohn14's Avatar
Do only one at a time. My dealer moved mine, but it didn'y work with my radar mount.
jc
2004 R1100SA Pacific Blue
Old 06-08-2007, 07:52 PM
I have to ask, what are the "low bar alignment tabs?"
'99 R1100S Mandarin & pretty darn stock. Heck, even the clock is set right.
Old 06-09-2007, 08:00 PM
hey brent, if you do it, and its not too much bother take a few before during and after pics... i was thinking of tryin this some weekend for $hit$ and giggles, then putting it back.... id like to at least see it done though....
Old 06-09-2007, 08:34 PM
Thread Killer
Steve Carlton's Avatar
See the picture below and notice the longer tab with the hole drilled in it for a screw to go through and into the underside of the triple clamp. These holes are plugged:
This one isn't:
Handy-dandy reading material that I found. You can see in red the keywords that I used in the search function (upper right):
relocate bars from high to low
Hi to low bars switch questions
switching to 'comfort bars'
handle bars
08 HP2 Sport
95 Triumph Tiger
85 911 Carrera
Old 06-09-2007, 09:07 PM
Many thanks for all the info
All,
Thanks for the prompt replies, and clarifying this for me. I will post pics of the before and after when I get it done.
work.
Old 06-10-2007, 12:26 PM
i did the high to low swap this morning... really seemed like there was gonna be a trick any minute. things in my life generally arent that easy.
pretty cool really, i think im gonna leave them down for a while, its not as low as i envisioned it feeling.
but now i cantfind my camera wire.
Old 06-10-2007, 02:04 PM
[QUOTE]Originally posted by Steve Carlton
[B]See the picture below and notice the longer tab with the hole drilled in it for a screw to go through and into the underside of the triple clamp. These holes are plugged:
Who makes those anti rotation brackets?
2004 BCR
2004 ZRX 1200
2003 HD SERK
Old 06-11-2007, 03:16 AM
roger albert's Avatar
Suburban Machinery.
I have a used set in near perfect condition that I'd let go for $75 if you happened to e interested.,
99 R11S w/ BBP, InDuct, Öhlins, PVMs, Braking, SJ-Filter, ZTech, HIDs
D675 R90Cafe R60/2 M900 SV650-SS CBR150R XR125 & CRF175 Motards
OnRoad OffRoad Cycles, Austin, TX: BMW, Ital, Suspension, Electrics
Dealer for K-Tech, JRI, GP Suspension, Penske, Öhlins, RaceTech, Elka, Wilbers, IKON & Works
www.ororcycle.com
CMRA EXPERT #841
Various Formula 5, 6 & 7 championships 2006-2012
A3, Navigator,
Old 06-11-2007, 05:30 AM
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
