Does the stock center stand for a R1100S work with the taller sports suspension on a Boxer Cup Prep model? I was told that it will not work.
Any one installed a center stand on their BCP with the sports supsension? Mine is an 02 silver R11S BCP with 5.5 inch rim and the yellow spring rear shock with no belly pan. TIA |
TIA
It won't lift the rear tire off the ground. I used 1" metal tubing cut in half lengthwise and had it welded on the feet. Gives clearance on concrete floor. Welcome on, where you located? Jim
down to jap bikes that run, a Ural, and a dead Norton |
IF you need to purchase one to hack up I will be selling mine in about a week.
Yes, BMW does make motorcycles..... 2000 R1100S Ztechnick exhust FosterRad Fuel Chip Ohlins F&R BMW MOA#125237 http://empeg9000.blogspot.com/ |
Thread Killer
The prep's suspension is only taller because it has the shorter paralever arm. A centerstand will work fine, but as Jim said, your tire will (probably, I think) touch the ground. But it'll be solid. You could also buy the longer arm for $80 or less, or swap with someone here for free. The steering will slow down a bit, but you'll gain a little more stability, too.
Spirited riding on uneven roads will cause the centerstand to touch down occasionally. Not a biggie, though.
08 HP2 Sport 95 Triumph Tiger 85 911 Carrera |
Any one using the Wunderlich S-Lifter stand (thru bmwsantacruz.com) and is it ok to use for storage in the garage? I have a 82 R100RS on center stand in my garage and would like to park my 02 R11S next to it that way as well to conserve space.
The thought of installing a center stand with the rear wheel still on the ground and the holes for the workstand now blocked no longer seems appealing. I am used to being able to spin and tug my R100RS with it in the garage. Thank you all for your inputs. Jim, I am located in Orange County, CA
John 2002 R11S Boxer Cup Prep 1982 R100RS |
Hope this helps, --Jim
--Jim 2002 M3, 6MT 2003 R1100SBX, Staintunes, FIM Chip, Öhlins 2009 Element 2013 Volt |
"I see nothing..."
Just throw a 2x4 under the kickstand and it should
get the rear off the ground.
TiM, ______________________________ 2005 R1100S BCR with White PVMs 2009 Aprilia RS125 with GIANNELLI full system, Bitubo shock, etc. |
Thread Tools | |
Rate This Thread | |
