Lennie's Rocket Sprockets
Buy a set and install them right now. Will be some of the best money you've spent on your S, especially if you've done intake and exhaust mods.
Ride Far - Ride Fast
tell us more
74 R90S, 77 R100RS, 85 K100RS, 2-87 K100RS 99 R11S 2002 Blue and White GS ... the prettiest ![]() 2008 KTM 950 Super Enduro long distance gravel road and general hooligan bike. Now an R11GS and a 650 Dakar |
130 plus shipping from Australia, about 4 bucks shipping. Very high quality hardware. Advances cam timing 9 degrees. Easy to install. Changes the acceleration characteristics of the S dramatically, and I do mean dramatically. Lennie says the sprockets drop the top end horsepower by about 2-4%, but I ran my S up to 140 by the speedo today, and it had a lot left. Couldn't tell any top end difference, but the midrange felt like a Honda CBR. Will now cold start without the enrichener and idles smoothly at 1k rpm. The rpm needle moves as fast in 4th gear as it does in 2nd or 3rd gear. My 2 cents worth.
Anyone else care to share their experiences?
Anyone have contact details? |
I wanna Live 'til I die!
I'm curious too... emailed him. I'll keep you guys posted on the results.
Ralf Wilkowski Light travels faster than sound. This is why some people appear bright until you hear them speak... https://www.facebook.com/Uncommon-Adventures-by-Rick-Ralf-681965548931729 2005 R1200GS - 20014 KTM690 Enduro - 2011 Husky TE250 |
I was going to buy them a few years ago and then someone misinstalled them or something and had a problem and never got around to it again. Not the sprockets fault but I wondered about my ability to do the install.
No try, do or not do
phoenix, you need to pull the heads to install these, right? if thats the case it will give me an opportunity to clean up the exhaust and match the intake
2017 R1200GSW Rallye Shreddr Signature Model |
The heads will not need to be removed, access to the Cam sprocket can be achieved with the cyclinder covers removed and the Cam Shaft Sprocket cover.
1993 R100GS PD 2003 R1150R Edition 80 2003 R1100S BCR Wanted - 1939 R50 TT or RS54 Rennsport Last edited by Geoff Anstey; 06-16-2007 at 07:57 AM.. |
True,
Lots of old threads on Lennie's sprockets. Good info and good product.
99 R11S w/ BBP, InDuct, Öhlins, PVMs, Braking, SJ-Filter, ZTech, HIDs D675 R90Cafe R60/2 M900 SV650-SS CBR150R XR125 & CRF175 Motards OnRoad OffRoad Cycles, Austin, TX: BMW, Ital, Suspension, Electrics Dealer for K-Tech, JRI, GP Suspension, Penske, Öhlins, RaceTech, Elka, Wilbers, IKON & Works www.ororcycle.com CMRA EXPERT #841 Various Formula 5, 6 & 7 championships 2006-2012 A3, Navigator, |
If you're careful, they're not a hard install. One of the main things is to follow the BMW shop manual to the letter. Start with the right cylinder, on TDC, paint the link on the side of the sprocket pointing to the space between teeth. Just remember that when you spin the engine after install, the paint marks won't line back up. While teaching myself how to position the sprocket, I tied a length of strong nylon thread to a hole in the sprocket in case I dropped it. Also, I thinly coated the tips of some needle nose pliers with silicone rubber for grip to work with the sprocket through the cam cover hole. Once installed, I tapped the locating pin to bottom it in the cam slot, then used hi-temp silicone to fill the 1mm hole before tightening the bolt and thick washer to 44 f/p or 60 Nm. Tapping the pin in gives you 3mm in the sprocket and 3mm in the cam slot. You don't have to, I just felt more comfortable doing it. On the left side, absolutely make sure you remove the cam chain tensioner first. I made my own tool (space is tight) out of a 11/16 box end wrench cut down to a 1-inch nub to use after getting the tensioner bolt loose initially.
Another thing, Lennie is an absolute sweetheart to work with, doesn't mind you shooting him questions. |
Now I am confused. Do these work on the 1200 or 1100?
This is for the 1100S. I'm going to post a detailed chart for the install.
...mine are on the way to me! Between teh exhaust I am building, the PCIII and the sprockets, the S should be well on her way to become my "main" bike... the can do it all bike... so to speak... even though I am eyeing a HM Duc... but I want to ride it first... which I probably shouldn't do...
whatever happened to go in deeper and come out harder?
'04 R1100s. I changed a couple o' things. |
Butch Barf,
This post relates to the R1100S. The part number for the cam sprockets for the R1100S and the R1200S is the same. I have yet to try them in a R1200S and when I get my next batch would like a volunteer to try them.
Lennie www.boxer-performance.com 1998 R1100S Yellow is the best (now departed from my life) |
Living on borrowed time!
Lennie, PM'd ya, buddy!
Better a has-been than a wanna-be 'I am John Andrew Moffett of the Clan Moffat and by god I live, love, seek, fail, grieve and die as I so choose and I call no man master save me'. |
Lennie,
When you are ready let me know. I kinda like the idea of being a guinea pig. If you wish, you may reach me at intra@optonline.net BB |
Pnoenix... a few day ago I ran into a thread where you nicely described your install process with pictures and text... now I can't find it anymore if my life would depend on it!?!?
...any guidance would be greatly apreciated.
Signit: The original was posted by member pdonnell on 1/7/03.
Google: Lennie's Cam Sprocket Replacement 101. There are a couple of mistakes, however, that might throw you. One involves the paint marking, another putting the cam lobe into the right position. I created a thing called "Lennie's Cam Sprocket Replacement For Newbies" as a jpeg. Send me a regular e-mail and I'll send it to you. |
Progress report: Went out riding with jarhead Saturday near Lake Texoma, with now more than 400 miles on Lennie's sprockets. No idle change, almost zero vibration up to 5k rpm, smooth as silk on the road. Cold starts with a bump at 70 degrees, although cooler weather might change that. They do everything Lennie said they would. Jardhead has his S really spiffed up and looking great. Great ride, so green down here it almost hurts your eyes.
Thread Tools | |
Rate This Thread | |
