Thanks. all . Well its Tuesday and time to pay BMW a visit. I'm stumped. Have replaced TPS, set at 385. Have performed aleak down test ,no burnt valves. Replaced the coils,wires and the o2sensor. The plugs look fine but have been replaced twice. I've run injector cleaner through. Cleaned the left side injector. Twin maxed , and used vacumm gauges to balance. Cables seem to be operating fine. Replaced o rings on the brass screws. Checked for air leaks. I'm stumped. Its time to see which sensors has taken a crap, off to BMW. Thanks for all the support and feed back.
The bike runs fair after being warmed up. But after sitting and restarting its like a popcorn machine.
dee jones
Old 06-19-2007, 04:30 AM
Do not take too seriously
throttlemeister's Avatar
Have you checked the MAP sensor?
BMW R1100S 'Bumble Bee' | HyperPro 3D F&R | motoyoyo clamps | Staintune | some other bits
BMW K1200S 'tri-color ICBM' | WP ESA rebuild to specifications | lots of other bits
http://www.sport-touring.eu | http://eurotravel.photos
Old 06-19-2007, 05:54 AM
Man it's flat out here!
R111S's Avatar
What about the Timing Sensor?
"What I've tried to do in the two books I've done, Signature in the Cell and Darwin's Doubt, is to show just how weak the materialist's hand is in explaining the key events in the history of life. ... We would encourage people to roll up their sleeves, do their homework on this." Stephen Meyer PHD
Old 06-19-2007, 04:35 PM
unsafe at any speed
wswartzwel's Avatar
Dee tells me his dealer spent all day troubleshooting, and told him the throttle body stop was out of adjustment...
Hopefully it is fixed, as he and Denice are leaving for a ride to Canada tomorrow. Bamf I believe is their destination.
Bill Swartzwelder
2002 R1100S Prep/2006 BMW R1200GS
1969 BSA StarFire
Old 06-19-2007, 08:38 PM
Yes Bill, is right. I'm on my way to see if the bike is indeed fixed. All day to find a set screw out of adjustment. Don't know how this moved I have never touched it.
This ones gonna hurt. OOuch
dee jones
Old 06-20-2007, 05:07 AM
roger albert's Avatar
Makes sense. That's why I'd asked about the throttle plate openings and if they exactly matched. W/o those matching, everything else is just twiddling around the margins. Hope they have it for you Dee. Good luck.
99 R11S w/ BBP, InDuct, Öhlins, PVMs, Braking, SJ-Filter, ZTech, HIDs
D675 R90Cafe R60/2 M900 SV650-SS CBR150R XR125 & CRF175 Motards
OnRoad OffRoad Cycles, Austin, TX: BMW, Ital, Suspension, Electrics
Dealer for K-Tech, JRI, GP Suspension, Penske, Öhlins, RaceTech, Elka, Wilbers, IKON & Works
www.ororcycle.com
CMRA EXPERT #841
Various Formula 5, 6 & 7 championships 2006-2012
A3, Navigator,
Old 06-20-2007, 07:54 AM
Thanks all, its running smoooth . were packing up and getting ready to do some rain ridin! BMW was gracious and only charge me for 3 hours. There still is a little compassion in the motorcycle world.
I wanted to let you guys know that they gave me an R1200R new as a loner. Ran out of gas with 15 miles showing on the reserve . Well time to finish packing. Thanks everyone. Roger you were spot on.
dee jones
Old 06-20-2007, 08:45 AM
unsafe at any speed
wswartzwel's Avatar
You should pay Roger too then!
Bill Swartzwelder
1969 BSA StarFire
Old 06-20-2007, 08:50 AM
Banned
I guess that is the idle stop - that gets screwed up when people who used to fool with carbs wrongfully think they should do a zero=zero on a TB. Checking the butterfly openings with a home-made wire gauge would have caught it.
But shouldn't this have been detected with Dee's TwinMax check?
Even if the stop(s) were misadjusted (likely just a wee misadjustment because a big change is unlikely) but if the BBS(s) kind of corrected for that at idle, there still shouldn't be a much funny about the way the bike runs.
Old 06-20-2007, 08:53 AM
Nope, twinmax won't detect that. Nor any other vac gauge.
0=0 still valid. Nothing wrong there.
No again, I'm afraid. Doesn't take much to throw these off.
Dee's bike is a case in point.
Glad you got it sorted Dee. It's easy to do more damage than good while rooting around. (Did it to myself on the SV a while back - needed a dyno to figure out where the problem was) I saved myself some cash by getting the top end jetted just right, but botched the low/middle in the process. Had to ante up for some dyno time anyway. In retrospect, I could/should have found it myself, but it doesn't always work out that way. Happens to all of us.
Good riding.
www.ororcycle.com
CMRA EXPERT #841
A3, Navigator,
Old 06-20-2007, 09:04 AM
Living on borrowed time!
JonyRR's Avatar
'when people who used to fool with carbs wrongfully think they should do a zero=zero on a TB'
so, Ben ******, still spewing nonsense as Peter Parts, eh?
Better a has-been than a wanna-be
'I am John Andrew Moffett of the Clan Moffat and by god I live, love, seek, fail, grieve and die as I so choose and I call no man master save me'.
Old 06-20-2007, 12:12 PM
Who's that? (somehow I have a feeling I know, but I am not sure..)
Old 06-20-2007, 12:37 PM
I wanna Live 'til I die!
signit98's Avatar
Send a message via AIM to signit98
Here's a question, Roger... if you do a 0 = 0 and you bring the voltage back up wuth the throttle stop screw... shouldn't you somehow equalize the other side's screw as wll to the same throttle opening?
Isn't that why Dee's bike was out of whack... if I understand correctly... none of the procedure's descriptions mention that...
Ralf Wilkowski
Light travels faster than sound. This is why some people appear bright until you hear them speak...
https://www.facebook.com/Uncommon-Adventures-by-Rick-Ralf-681965548931729
2005 R1200GS - 20014 KTM690 Enduro - 2011 Husky TE250
Old 06-20-2007, 12:43 PM
Nevermind, I did a search. After a few encounters I stopped visiting a particular other site cause I couldn't take (and fight) the BS anymore.
Old 06-20-2007, 01:17 PM
R111S's Avatar
One of my Brit riding buddies told me to check the TB Stops by holding on to one TB with fingers (feel the clack when it reaches the stop) while positioning my ear next to the other TB (hear the clack when it reaches the stop). Just roll the Throttle closed and you'll know immediately if they're not in sync. I checked mine shortly after I bought it and they were not in sync...I adjusted the right side cable and I've had minimal surging issues since then. I also use Autolite 3923 Spark Plugs.
From my MSWord Log File:
23AUG2004 - @19,135 Miles I followed the advice from one of my British riding buddies, Chris Barnes who owns a 2004 BMW R1150R Rockster, regarding Throttle Body Synchronization. While the engine is OFF, listen to the Throttle closure to hear the Butterflies hit their respective STOPS. Make sure that they STOP simultaneously during Throttle rolloff to Low Idle position. Mine did not STOP simultaneously. The RH side hit the STOP slightly later than the LH side. Chris said to only adjust the cable of the RH side (without the Throttle Position Sensor) and do not adjust the STOP Screws. I made the adjustment in about 3 minutes and now they STOP simultaneously.
Old 06-20-2007, 07:55 PM
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
