Towjam's Avatar
1200ST - rear rotor heat question
Under normal riding conditions (street riding, not dragging the brake), how hot should I expect the rear rotor to be immediately after riding? For grins and giggles, I checked it last night after about a 20 mile in-town ride and it was literally too hot to touch with my bare finger. Up on the center stand, I notice a little drag when rotating the wheel but this is typical of any bike I've had. (This is a new bike - about 800 miles on it.)
Cheers!
Towjam
...more BMWs, Buells, Harleys and Hondas than you can shake a stick at!
Old 06-19-2007, 04:40 AM
Do not take too seriously
throttlemeister's Avatar
Pissing hot.
Think about it. You are bringing something in the order of 600 pounds to a stop only by simple means of friction on two small and thin metal discs. All that energy is being transferred into heat only.
BMW R1100S 'Bumble Bee' | HyperPro 3D F&R | motoyoyo clamps | Staintune | some other bits
BMW K1200S 'tri-color ICBM' | WP ESA rebuild to specifications | lots of other bits
http://www.sport-touring.eu | http://eurotravel.photos
Old 06-19-2007, 05:57 AM
roger albert's Avatar
Agreed.
But if you're concerned, drive the last few miles home w/o using the rear brake. If it's still hot, THEN you have an issue (dragging)
Otherwise, you're fine.
99 R11S w/ BBP, InDuct, Öhlins, PVMs, Braking, SJ-Filter, ZTech, HIDs
D675 R90Cafe R60/2 M900 SV650-SS CBR150R XR125 & CRF175 Motards
OnRoad OffRoad Cycles, Austin, TX: BMW, Ital, Suspension, Electrics
Dealer for K-Tech, JRI, GP Suspension, Penske, Öhlins, RaceTech, Elka, Wilbers, IKON & Works
www.ororcycle.com
CMRA EXPERT #841
Various Formula 5, 6 & 7 championships 2006-2012
A3, Navigator,
Old 06-19-2007, 07:00 AM
Towjam's Avatar
Originally posted by roger albert
Agreed.
Unfortunately, I would have to coast. I have the partially linked ABS system.
Guess I could do a Fred Flintstone and drag my feet.
Cheers!
Towjam
Old 06-19-2007, 07:07 AM
You will recognize drag immediately, as the wheel will stop almost instantly if you give it a swirl on the stand. And the disc will be blue. Which is ok if you have been playing hard and been hard on the brakes, but under normal conditions it is an indicator of something being not entirely right.
Old 06-19-2007, 09:31 AM
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
