Dunlop Qualifier vs D208
I just ordered a new Dunlop Qualifier for my S. I chose it to replace the runout D208 because the front tyre is good for one more rear. Has anyone run out a Qualifier that can compare it to the D208?
Do not take too seriously
No anwer to your question, but why the Qualifier and not the new Qualifier RR. Supposedly (according to the Dunlop rep) more grip dry and wet and longer lasting due to dual compound technology.
BMW R1100S 'Bumble Bee' | HyperPro 3D F&R | motoyoyo clamps | Staintune | some other bits BMW K1200S 'tri-color ICBM' | WP ESA rebuild to specifications | lots of other bits http://www.sport-touring.eu | http://eurotravel.photos |
Thread Killer
I've had them both. The D208 just feels real nice before it warms up. The Qualifier has more stick than you'll ever need, but didn't last very long. I'm finding the feel of the M3s the best, and they last longer, too.
08 HP2 Sport 95 Triumph Tiger 85 911 Carrera |
The Dunlop Qualifier Race Replica is not available in the US markets as far as I can tell. The Qualifier was the repalcement for the D208ZR. If you have a US source for the RR with good pricing let me know.
I'd have to have a look, but it's weird anyway. Considering the US is Dunlop's largest market with a huge market share, whereas Dunlop has just a tiny market share in EU.
Grip does seem much better on the Qualifiers vs. the D208. Response is much improved, the point Im double checking pressures wonder whats going on. Almost too darty in some case. I've only had them a few thousand miles, so dont know everything yet. I feel there is less difference warm to cold on these, where the D208's would be pretty slick when cold and warm up nicely. Cant comment on wet performance. Wear looks good so far, but already getting a hint of irregular wear on the fronts like the D208's, so I have a feeling longevity will be worse on the Qualifiers. Ride is diffinitely down. Impacts are sharper and larger than the D208's, but again, maybe some pressure tuning with more seat time will help out. Bottom line, I think from a performance standpoint in terms of handling, grip, etc. they are improved.
2002 BMW R1100S 2009 Pontiac G8 GT 2006 Mitsubishi Montero 2005, 1988, 1969 Corvette Coupes 1992 Mitsubishi 3000GT VR4 |
Biggest Member
The qualifiers are quite sticky. the only problem I've had with them is that when they go off, they give very little warning. Unlike the Pilot Powers, which will get a little greasy and give you gentle little slides as a reminder that they'd like to be changed, the Qualifiers just went off, unfortunately at about 85mph, in turn 1 at BeaverRun. this was on my GSXR-750, though and the tires had seen about 6 trackdays and god knows how many heat cycles- damage was limited to a ground down foot peg and a broken brake lever. I realized that I'd reached the limits of street tires on the track and promtly switched to DOT Race rubber. heat cycling isn't likely to be much of an issue for most of you guys. as street tires go, they're pretty good and light years ahead of the 208's
Cheers, Lance |
Thread Tools | |
Rate This Thread | |
