I wanna Live 'til I die!
Ohlins candyland on ebay...
...this guy has 420 original coil over springs for ohlins shocks and he is selling them for $20!!! each...
I ordered some for my sport shocks... and, even if it does not work... so what, I spent $20 for a spring that I will use eventually! I just talked to him, he seems nice and ligit... and he's looking for stuff that will fit my bikes... go and search for number 170124701742 It was worth it to me...
Ralf Wilkowski Light travels faster than sound. This is why some people appear bright until you hear them speak... https://www.facebook.com/Uncommon-Adventures-by-Rick-Ralf-681965548931729 2005 R1200GS - 20014 KTM690 Enduro - 2011 Husky TE250 |
is there really any benifit to putting an ohlins spring on factory shock? can this even be done?
http://lightfighter.smugmug.com/ |
...I will let yoou know, as I have ordered the shocks needed to "spice up" my sport suspension.
The ohlins internals are different with different valving, flow ratings and such, but the springs are different as well... harder with different progression rates. I look at it this way: "if it works, I have a $40 upgrade that I will enjoy... if not, I have some cool ohlins springs to take of space on my crowded desk and collect dust"
Do not take too seriously
I replaced the original (way too soft) sports springs on mine with HyperPro springs and the difference is night and day. $40 is an excellent deal and possibly the best and cheapest upgrade possible.
BMW R1100S 'Bumble Bee' | HyperPro 3D F&R | motoyoyo clamps | Staintune | some other bits BMW K1200S 'tri-color ICBM' | WP ESA rebuild to specifications | lots of other bits http://www.sport-touring.eu | http://eurotravel.photos |
...Thank you, Sir... even more reason to look forward to the outcome of that experiment... the guy also said that - should it be needed - he will gladly exchange the springs to springs with different ratings (a step up or down if neccesary).
Depends on the required rate. The O springs are no better or worse than any other brandname spring. Just a way of getting the right rate for the rider. In many cases, a heavier spring can work worse when you run into a lack of rebound damping, but it can sometimes work. > can this even be done? Just a matter of matching ID, OD, Freelength, and rate. Case by case basis.
99 R11S w/ BBP, InDuct, Öhlins, PVMs, Braking, SJ-Filter, ZTech, HIDs D675 R90Cafe R60/2 M900 SV650-SS CBR150R XR125 & CRF175 Motards OnRoad OffRoad Cycles, Austin, TX: BMW, Ital, Suspension, Electrics Dealer for K-Tech, JRI, GP Suspension, Penske, Öhlins, RaceTech, Elka, Wilbers, IKON & Works www.ororcycle.com CMRA EXPERT #841 Various Formula 5, 6 & 7 championships 2006-2012 A3, Navigator, |
i went ahead and ordered one for the rear. he says the front springs he has would be too stiff for my app. that he would say this tends to make me believe he is credible. the rear will make a nice weekend tinker project...
Barback King
...um, Roger, aren't you going to do the safety talk?...
R11S CNC BARBACKS Now an R1200GSW rider... |
safety talk??? am i about to kill myself?
Probably not kill yourself, but if you're not careful, you can remove your finger, or, as in my case, despite many years of experience, nearly remove your finger. I'm sure there are some gruesome photos here somewhere, as well as examples of very bad typing, which I blame equally on the pain, the drugs, and the external fixating pins sticking out of my middle finger.
Do be careful. After 6 months and lots of PT and $$, I'm up to 75% motion
oh, ok... my ase cert expired a decade ago, but ive been around struts a bit.. a wise warning though. compressed springs are nothin to messwith if you dont know what you are doing.
Underwater basketweaver
So this begs the question, on a motorcycle, is it better to have the shock do most of the work or the spring do most of the work?
I know that my personal opinion on my other BMW (3'er) is for the spring to do the majority of the work and to have the shocks dol less work. My current coilovers (Bilstein PSS9) are sprung way too soft and the shock is overloaded by my style of driving. Anyway, suspension tuning on a bike isn't exactly the same thus my question.
'04 BCR '05 R12GS '08 HP2 Sport |
The spring should always do most of the 'work' Car, Motorcycle, bicycle. True of any nonactive system.
Living on borrowed time!
I put bilsteins and H&R springs on my 530I last year.
I had two GOOD quality screw-type spring compressers and still I had them bent a bit to get the spring compressed enough to attach the upper strut mount. be veeeewwwwy caweful wid dis. Get GOOD quality spring compressers and work like a member of the bomb squad...cause that compressed spring IS a bomb waiting to go off in a linear direction. I screwed this up once on a GM pickup adding some rancho springs and I had a spring go thru the fender sheetmetal. at that, I felt lucky.
Better a has-been than a wanna-be 'I am John Andrew Moffett of the Clan Moffat and by god I live, love, seek, fail, grieve and die as I so choose and I call no man master save me'. |
a center yoke fixed strut compressor is a much better deal... those side mountedspring compressors are not really designed to deal with coil over shock setups at all.
True, but try to find the good pro-grade stuff dimensioned for bike size springs. Plus, older bike shock designs have a lot of issues with spring/bumper-cup clearance (exactly the situation that bit me) The auto experience is worlds better than none, but tool availability (lack thereof) prevents all the practices from crossing over.
dang. until i read that, i hadnt looked. i justfigured one of the 20 or so adapters on my buddy's strut compressor would work. well, ill figure something out. maybe just takes my chances with side clamps. maybe i can fab up a mini strut compressor. that'd be what the tool man would do!
kinda, sorta off topic, but i have friends getting into stock car racing and on a nascar set-up, one pound of air pressure in a single tire is the equivalent of a 60 pound spring increase on that same tire.
useless info, but i found it fascinating.
'04 R1100s. I changed a couple o' things. |
i wonder if the relativly small volume of air in a cycle tire would change that ratio... im not that mathmatically inclined.... i assume youd be using air pressure to adjust for traction on the track though (i doubt i'll ever see a track, even though i'd like to)
Hey, if an adapter works well, let me know what it is.
I'd be glad for the education. Brad, I'm sure there is some super rough equivalent, but those rules only work over a narrow (linear) range for a car, and much less so for a bike with the relatively poor sprung to unsprung mass ratios. In any event, a far smaller value for a bike. The equivalent manifestation on a bike is lowering tire pressure when a light rider cant' get a tire to heat up enough to stick well and/or the spring is stupid-heavy for them. Then we just drop the pressure.
Thread Tools | |
Rate This Thread | |
