Soliciting GPS recommendations
I have been looking at GPS devices for my motorcycle, and have been pretty impressed with the Garmin Quest 2. Does anyone have experience with the Quest or Quest 2 for their motorcycle?
The one feature that I'm not too keen on with the Quest is the speaker on the power plug. What's up with that? Can you still get voice directions through an on-bike communication set up like Autocom with the Quest? Also, if you have a favorite GPS for motorcycle use, I would also be interested in your comments. My main requirements are: - Less than $500 USD for the GPS unit itself (not including mounting device) - Waterproof - Re-routing capability Any information you would like to share would be appreciated. Thanks in advance. |
I have the Quest. I like it except for what you mentioned about the speaker on the power cord I'm assuming that you can rip open the box and cord and wire your own headset in but I have'nt tried. I wonder if the newer gps units are faster at recalculating routes for when you miss your turn. If you miss it with the quest you usually need to pull over and wait for it to calculate. Also its made for the road so geocaching with it is a bit difficult. The cool thing about it though is that you can pull it off the bike and carry it around with you
I was just looking at the Garmin Zumo 450 on a website. These things are going for about $500 OTD. They are the same as the Zumo 550 without the bluetooth capabilities. I have no less than 6 gps systems at home right now (all are primarily for offroad use), but for a street bike I really like the capabilities of the Zumo.
Check it out, it looks like a great system.
Tim Howard-Sierra foothills Proud owner of half of my stuff Thanks to the Ex! |
Underwater basketweaver
I've had the 2610 and currently have both the 2720 & 2820. I picked up the 2820 used for $500 just recently. Anyway, if you don't care for using the GPS away from the vehicle, these units are pretty good. If you want internal batteries on the unit, then yeah, either the Zumo or the Quest 2.
'04 BCR '05 R12GS '08 HP2 Sport |
Garmin 2730
Comes preloaded with all of north america, has an MP3 player and XM satellitle built in, and is waterproof. I've seen them just about $499. Failing that I would recommend the 2610. Thats what I have.
Yes, BMW does make motorcycles..... 2000 R1100S Ztechnick exhust FosterRad Fuel Chip Ohlins F&R BMW MOA#125237 http://empeg9000.blogspot.com/ |
I had the Quest2 and sent it back for the Zumo 550. Quest2 screen is not nearly as bright as the Zumo. You cannot move the screen around live with the Quest2. Quest2 processor is way slower than the Zumo, Zumo has Garmins fastest processor in it.
I do like the size of the Quest2, it is great if you do business travel....but overall, I found it menus way harder to navigate than the Zumo. For what its worth, especially if budget is not the primary consideration, I think the Zumo is a much better route to go......pun intended ![]() Robert
moved from Chicago to Charlotte so I could use the sides of my tires ![]() |
What's up with the Nuvi? That one seems pretty hot lately, and easily moved from car to bike.
'01 BMW R1100SLA. Turbo. < = > Less is More. If you think you know it all, you obviously don't know anything. |
I got a Streetpilot 2720 two months ago new for $360 at amazon. Is water proof. I'm very happy with it.
2011 S1000RR 2006 R1200GS 2013 CRF250L 2004 BCR. Sold |
Do not take too seriously
BMW R1100S 'Bumble Bee' | HyperPro 3D F&R | motoyoyo clamps | Staintune | some other bits BMW K1200S 'tri-color ICBM' | WP ESA rebuild to specifications | lots of other bits http://www.sport-touring.eu | http://eurotravel.photos |
Garmin 450. working very well.
R1100S 2.0
Although I haven't decided which way to go on helmet integration, this unit will give you nav with TTL that announces street names & locations (rather than "take your next right," it's "take a right on Howard Avenue"), along with MP3 playback & phone w/bluetooth all in one unit. I'm pretty happy with it for both car & bike use. ![]() ![]()
2002 R1100SBX, sold |
I wired my helmet with a Chatterbox full face speaker/mic kit and wired up my own mini-DIN plug. This all goes to a Mix-it2 audio mixer where the V1 also goes in. It all works pretty seamless. The wire isn't that big of a deal and the few times I've gotten off the bike and forgot to disconnect, the mini-din simply pulls apart without damaging the wiring.
R1100S 2.0
Oilhead, the Streetpilot 2820 (and maybe ALL of the SPs) have the speaker integrated into the plug, but has separate mic & headphone plugs. The way to go with audio is into your helmet, regardless. EDIT: I just stumbled across the Sony Ericsson HBH-DS970 stereo bluetooth headset. Beware the $30 Hong Kong fakes on eBay... when I find a reasonably-priced real one I'll probably take the plunge & try it alone or solder on the Intaride helmet headset.
2002 R1100SBX, sold Last edited by DeltaNu1142; 06-27-2007 at 10:12 AM.. |
Assuming you're dedicating it to bike use, I'd get one of the Zumos. Even small things like putting the buttons on the left side can make a big difference in useability and this unit is designed for motorcycling.
That being said, I'm soldiering on with my 60Cx which is just an incredibly versatile unit in all roles - road, car, hiking, bicycliing, whatever. I detest power dongles so I run on AA's - with a RAM mount, popping it out of the mount and into my tank bag is literally a 5-second deal. But it the dedicated motorcycling mission, you do have to look past the small/dim screen and it takes a while to work through some of the glitches in how it exchanges routes with MapSource. The Qwest2 appeal is that you get the unit with a good built-in database, so it's a really good value for the money. But today, I'd spring the extra for the Zumo. - Mark |
How are you guys keeping your headsets on when putting on your helmet? Also if you use a headset do you wear earplugs?
R1100S 2.0
I wear earplugs (Max NNR 32) thus the need for the audio mixer. I wired my helmet up with the chatterbox headset (between the padding and the padding sheath in my Shoei). I don't listen to music while riding so all I care for are the Ka beeps (V1) and direction prompts from the 2820.
As for the small quarks with Mapsource and the GPS, it takes some getting used to but it also helps to know how the routing logic 'recalculates' routes on both the GPS and PC.
R1100S 2.0
The battery powercord for the 2720 has a jack connector for speakers builtin and I have a waterproof mini-DIN connector in the wire going there from my helmet. If I don't have my GPS on, I have a piece of wire about 6" long hanging from the side of my helmet. That's long enogh to be able to see what you're doing (just) when plugging in the cable with your helmet on, and short enough not to even notice it without.
The wire plugging in my helmet is a curled wire so it is doesn't dangle all over the place, while still providing length when needed. All in all, it works great, gives very good sound and it's a very convenient solution for me. ![]() My kit. (25 euro) Kit for the 2820, with stereo sound for the MP3 player, and mic to operate with a BT phone. (45 euro) Hey, it works for me. ![]()
Thread Tools | |
Rate This Thread | |
