R12S: Valve check & adjust
Did the 6000 mile valve adjustment on my R12S yesterday. It's just like any other oilhead. I did try for the first time the HanSocket that Bob made me. Worked like a charm and I have perfect 8Nm torques on all my locknuts.
I did use a BMW TDC lock pin (because I have one). To install it, you need to remove the bracket for the rear brake fluid reservoir. Then it's a straight shot in. Here are some pics for views. Some valves needed no adjustment at all, some were a hair loose. I have an appointment at my dealer next week to check TB sync and to change the final drive fluid again. ![]() ![]() ![]() ![]()
Jon Maddux 08 M3/4 | 07 R1200S | 07 R1200RT | 01 M coupe |
Talk Less, Say More
Location: Moab Utah. Home of wierd red & orange radioactive stuff...
What is the TDC locking pin part number?
cRaIg CaRr 2000 Dyna FXDX, 2000 R1100S, R1200S, rNineT, F800GS, S1000XR, Jeep Rubicon, 2001 Corvette, 1978 Porsche 928. 22 pairs of shoes. 24 bottles of beer. Time Marches On and gone: 2010 F800GS, 2015 F800GS, 2007 R1200S, 2003 Dakar, Buell 1125r, 2001 F650GS. 1999 F650. 1998 HD Sportster Sport. 2010 F150, 1995 GMC Sierra ALL GONE |
I will look it up when I get home. Cheaper form Chicago. Price has gone up since I bought mine.
http://www.ascycles.com/detail.aspx?ID=1016
TDC locking pin is BMW part number 83300401523
Spark Plug Puller is 83300401700
What does the locking pin do?
Jim
down to jap bikes that run, a Ural, and a dead Norton |
Uh....who me?
Nothing that the sprocket indicator can't do, Jim (for this application). I've used the pin (I made one) and the phillips head in the spark plug hole and the mark on the sprocket to find TDC for setting valves and they all provide the same results. My findings were confirmed in my mind when I watched a Master Tech at BMW Atlanta find tdc using the sprocket mark. If you think about it some, the area on the back side of the cam is pretty wide, so being within 5 degrees either way is good enough and the sprocket mark set at 3 or 9 o'clock is just fine.
Bob Hancock '20 KTM1090 SuperAdventure S, '17 KTM 690er, '19 BMW F850GS, 2006 KTM 660R Dakar, 2001 Porsche Boxster S "There are times when good words are to be left unsaid out of esteem for silence." St. Benedict |
I would not go out and buy a TDC lock pin. You don't need it. I scored this one used, I have it, so I use it. The indicators are good enough.
On shim-adjusted valves I do always set the engine at a precise TDC point for consistency; I don't want to risk the extra work of swapping a shim just because a borderline valve has gone out of spec due to my setting the engine as a slightly different spot and chasing the variations in the cam base circle. But on a BMW with screw/locknut adjusters, where adjusting is just a minute or two extra vs. checking, I don't worry about it and just get it close to TDC using a soda straw in the spark plug hole. - Mark |
Thread Tools | |
Rate This Thread | |
