Which Rotella?
I've read 50+ posts that refer to using Shell Rotella oil but I don't know which specific Rotella product I should be looking for.
Rotella T Triple Protection 15w-40?
Rotella T Multigrade with Advanced Soot Control 15w-40?
Rotella T Synthetic 5w-40?
http://www.shell.com/home/Framework?siteId=rotella-en&FC2=/rotella-en/html/iwgen/leftnavs/zzz_lhn1_0_0.html&FC3=/rotella-en/html/iwgen/welcome.html
Castrol GTX 20w-50 is also readily available. Would this oil be suitable for the R1100S?
Old 07-05-2007, 12:25 PM
Personally, if you're using car oil, I'd use synthetic. So if you're going Rotella, I'd go the 3rd one. But for the air-cooled S, I think 5W-40 is just a little too thin unless you're gonig to be riding in a pretty cold climate. So I'd give the nod to Mobil 1 15W-50 synthetic instead.
Subtle tradeoffs with all oils, so it's not like there's likely to be a "wrong" oil.
- Mark
Old 07-05-2007, 01:03 PM
Moybin's Avatar
I've been running Rotella T Synthetic 5W-40 in my S for over a year, and in both my cages.
The S runs slightly quieter. It may burn a bit more oil, though it is difficulet to tell. Gas mileage is up slightly also. The 5W-40 Synthetic is formulated for the high heat of diesel engines, therefore I presume it to be better for an air/oil cooled gas engine, too.
'99 Black SA "OBSSSN" - gone but not forgotten.
Not all good technology is new, not all new technology is good.
.........Purple is Satire.........
Old 07-05-2007, 01:11 PM
pwillikers's Avatar
And no evidence of elephantiasis?
Elephantiasis cylinder head cover
Paul. '04 R1100S w/Öhlins an' stuff, '09 Buell 1125cr, '08 Suzi SV650A, '00 Suzi SV650, '97 328i (with sticky ass tires - I love this car even though its just a car). And the bikes I used to own: '68 Bultaco 100, '69 Honda CL450, '71 Kawasaki Mach III, '71 OSSA Pioneer, '72 Honda MR175, '72 Benelli 250, '75 Yamaha RD350 (then college), '83 Honda VF750F (then kids),'96 MZ Skorpion, '99 R1100S, '01 SV650 and '94 Honda VFR750F - most wrecked.
Old 07-05-2007, 01:12 PM
unsafe at any speed
wswartzwel's Avatar
Makes great cheese dip too!
Bill Swartzwelder
2002 R1100S Prep/2006 BMW R1200GS
1969 BSA StarFire
Old 07-05-2007, 02:30 PM
Moybin's Avatar
No evidence. I'm not baseline, though. I dilligently removed the OEM coating (never do that again) and had JonyRR apply black powder coat. Jony's paint job is holding up nicely!
Old 07-05-2007, 05:29 PM
unsafe at any speed
wswartzwel's Avatar
I think your Clutch master cyl. dripped a little fluid, and caused that... But I am not Monk or anything...
Bill Swartzwelder
1969 BSA StarFire
Old 07-05-2007, 05:34 PM
pwillikers's Avatar
Only $100 and shiny black valve covers could be yours too. I bet they'd look good on a silver s ... real good.
Old 07-05-2007, 06:33 PM
Moybin's Avatar
I'd be surprised that brake fluid could do that. After my fight with 2 cylinder heads and every solvent known... But that was one I did NOT try, so maybe, just maybe.
If I had to do it again I would just apply another coat over the OEM layers.
Old 07-05-2007, 06:55 PM
Anyone care to post on the topic of Rotella oil?
pwillikers's Avatar
Rotella, what a silly name. Sounds like a cheese food.
Old 07-05-2007, 09:12 PM
unsafe at any speed
wswartzwel's Avatar
I use in my KTM and it shifts nicely..And is still honey colored when I drain it out after 15 hours of use. I also like the design of the gallon jug. Makes it easy to pour.
In my S however I use Mobil1
Use a good oil of your preference, and change it often and you will not have an oil related failure.
Bill Swartzwelder
1969 BSA StarFire
Old 07-05-2007, 10:10 PM
Pwillikers - Sounds more like an italian pasta to me.
wswartzwel- Thanks for the info. Is "Rotella T Triple Protection 15w-40" a "good oil?"
Old 07-06-2007, 09:50 AM
unsafe at any speed
wswartzwel's Avatar
Depends on the application and your climate... I prefer a 5w-40 Synthetic for close tolerance engines.
It is generally better to wait till you have about 10K on R259 BMW engines before switching to synthetic.
Shell Rotella is very good oil..
here is all the info and opinions you could ask for.
http://www.shellusserver.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=3452&page=1
Bill Swartzwelder
1969 BSA StarFire
Old 07-06-2007, 10:02 AM
Thanks again. I have a 2000 R1100S that I bought last year. It only has 5,100 miles on it. Its in NJ where I will ride it in temps between 50 and 100 degrees. Unfortunately, I don't know the oil history on this bike.
Old 07-06-2007, 10:53 AM
bigscience's Avatar
the point in using oil for a diesel in the bike is that it has no additives like detergents or friction modifiers. there is less reason to use Rotella in our bikes since we have a dry clutch, but it's cheaper and just as good. if we had wet clutches the oil additives, which are there to cling to moving parts and lubricate them, would also be lubricating your clutch surface, which you would not want. Use the 5w-40. it has the lowest initial viscosity (the 5w bit) so you get quicker oil flow on start-up and lower overall 'drag' from teh oil, but it also can withstand high heat (the 40) so the engine wont suffer from oil breakdown if youre stuck in traffic.
if you want to really go silk purse then the 0W-40 synthetic from Mobil is the shizzle (it has additives though). it's what comes in Porches for just those reasons. downside is 7 bucks a quart.
google oil and morotcycle and spend your life sifting through the tons of hits.
Old 07-06-2007, 11:12 AM
Snob Pirate
geothepencil's Avatar
I used to think Rotella was a Japanese monster from the great science fiction epics, but after we got our Bobcat and I had to find diesel rated oil, I discovered the farm store was big on the stuff. I liked it better as a mythical monster.
geo
"She sips nitro... with Phase 4 heads! 600 horsepower through the wheels! She's meanness set to music and the ***** is born to run!" Barry, MFP mechanic
BMW/Yamaha/Suzuki
I've been ionized, but I'm OK now.
Old 07-06-2007, 12:45 PM
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
