Mark Estes's Avatar
R1100S spark plug boot puller
Where can I get a better one than the one that comes in the tool kit? The primary plug boot on my 2-spark seems to be very tight and the supplied puller just keeps slipping off.
Mark
2004 R1100S, 1975 R75/6, 2005 Yamaha Majesty 400
"that spending was required to simply establish BMW in the world of WSBK from its previous position as a manufacturer who built bikes for a solidly geriatric customer base." -- SuperbikePlanet.com
Old 07-08-2007, 07:01 AM
peterz's Avatar
Mark, make sure you are pulling on the loop only and not the body of the tool. Pulling on the loop tightens the tool's grip on the boot. Failing that, see if your dealer can get you the tool in this image capture from a BMW service video. I don't know what the rest of the part number is but I'm sure a friendly dealer will know how to figure it out.
2010 HP2 Sport (sold)
2004 BCR #36 (sold)
Old 07-08-2007, 08:06 AM
ChrisATL's Avatar
I ended up buying this one from Marc Parnes
HERE is a link to his website
Chris
'07 R1200GS
'79 GS1000S
Old 07-08-2007, 09:09 AM
Mark Estes's Avatar
Thanks, Chris. That's exactly what I'm looking for.
Mark
Old 07-08-2007, 09:55 AM
Are these wires different then the wires on my 2000 R1100S? I just changed my plugs and removed the wires by simply pulling on them. Is there a tool I should have been using?
Old 07-08-2007, 11:36 AM
The factory toolkit includes a plastic u-shaped doohickey that "hooks" onto the lips of the spark plug boot and makes it much easier to pull them off. You can generally go it with just your hands, but you have to have strong fingers and/or be willing to endure a little pain - the tool makes it much easier.
If you're pulling on the lead directly (as opposed to the boot), that's a big no-no.
- Mark
Old 07-08-2007, 12:32 PM
Mark Estes's Avatar
You don't need to use a tool if you can just pull yours off. Mine seem to be stuck on the plugs, plus the fact that I can't get my fat fingers in there to grab hold of the boot. The tool kit under the seat has a boot puller that slips into two grooves on the top of the boot. It's a plastic thing with a finger loop on it. I was having trouble with the tool slipping off the boot when I pulled on it. I was probably not doing it right. I did enentually get the boots off though. A little dielectric grease on the inside of the boots will probably make it easier next time, but i went ahead and ordered the Mard Parnes puller shown above.
Mark
Underwater basketweaver
SergioK's Avatar
Send a message via AIM to SergioK Send a message via Yahoo to SergioK
The underseat tool actually ripped the outer sheath of one of my plug wires - damn spark plug boot was on way too tight. I ended up having to replace the wire.
'04 BCR
'05 R12GS
'08 HP2 Sport
Old 07-08-2007, 01:22 PM
Thanks Marks. I wasn't pulling the wire but rather the lips of the spark plug boot. It wasn't terribly tough to pull and not painful at all but I have small, strong fingers from many years of guitar playing.
Old 07-08-2007, 01:47 PM
Do not take too seriously
throttlemeister's Avatar
This tool is for the twinsparkies, your 2000 is a single spark and has a lot more room for your fingers.
BMW R1100S 'Bumble Bee' | HyperPro 3D F&R | motoyoyo clamps | Staintune | some other bits
BMW K1200S 'tri-color ICBM' | WP ESA rebuild to specifications | lots of other bits
http://www.sport-touring.eu | http://eurotravel.photos
Old 07-08-2007, 10:14 PM
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
